Archived from groups: microsoft.public.windowsxp.security_admin (
More info?)
Heroine the Liquid CCCP wrote:
> i have the same problem
> i managed to delete all the viruses except for the one that infect my
> svhost under spoolserver32 or somethin
> heres a list of ip addresses that recently tried to log into my
> service
> 207.46.230.48 (port 80)
> 24.153.23.66
> 24.153.22.195
> 222.88.173.5 (port )
> 12.158.80.10 (port 80)
> one or two of these might be yahoo
Neither of you have computers that are free of malware. Follow these
malware removal instructions, doing everything with updated tools in
Safe Mode. If the instructions seem daunting, there is no shame in
admitting that. In that case, take the computer to a good local
professional, not a BestBuy or CompUSA type of store.
First delete all Temporary and Temporary Internet Files. Then:
1) Scan in Safe Mode with current version (not earlier than 2004)
antivirus using updated definitions.
Before you remove malware, get LSPFix (or WinSockFix for XP which you
can get from MajorGeeks) - see links below.
2) Remove spyware with Spybot Search & Destroy and Ad-aware. These
programs are free, so use them both since they complement each other.
There is a new version of CWShredder from Intermute. I would not
install the other Intermute programs, however. Alternately, there are
CoolWebSearch malware removal steps at SilentRunners.
Be sure to update these programs before running, and it is a good idea
to do virus/spyware scans in Safe Mode. Make sure you are able to see
all hidden files and extensions (View tab in Folder Options).
If the malware remains even after you used Ad-aware and Spybot, you can
scan with HijackThis. HijackThis is an excellent tool to discover and
disable hijackers, but it requires expert skill. See below for
HijackThis links, including sites where you can post your HJT logs. A
combination of HijackThis and About:Buster works well in removing the
About:Blank homepage hijacker. Again, this is an expert tool and
novices should get help with it.
3) If you are running Windows ME or XP, you should disable/enable System
Restore after the system is clean because malware will be in the
Restore Points. With ME, you must disable System Restore completely.
With XP, you can delete all but the most recent (presumably clean)
System Restore point from the More Options section of Disk Cleanup
(Run>cleanmgr).
4) Make sure you've visited Windows Update and applied all security
patches. Do not install driver updates from Windows Update.
5) Run a firewall.
Links to help with malware:
Software/Methods:
http://www.safer-networking.org - Spybot Search & Destroy
http://www.lavasoftusa.com - Ad-aware
http://www.majorgeeks.com - good download site
http://www.intermute.com/spysubtract/cwshredder_download.html
http://www.silentrunners.org/sr_cwsremoval.html. - SilentRunners
http://www.cexx.org/lspfix.htm - Repair Winsock 2 settings after
removing spyware
http://www.spychecker.com/program/winsockxpfix.html - WinsockXPFix.exe
HijackThis:
http://www.aumha.org/a/hjttutor.htm - HijackThis tutorial by Jim
Eshelman
http://aumha.net - forums
http://spywarewarrior.com/viewforum.php?f=5 - Spyware Warrior HijackThis
forum
http://www.wilderssecurity.com/
http://forums.tomcoyote.org/
General:
http://aumha.net - look under "Security" for various forums
http://rgharper.mvps.org/cleanit.htm
http://mvps.org/winhelp2002/unwanted.htm
http://www.aumha.org/a/parasite.htm - The Parasite Fight
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Malke
MS MVP - Windows Shell/User
www.elephantboycomputers.com
In Memoriam - MVP Alex Nichol
The world is diminished without him.
