Archived from groups: alt.sys.pc-clone.packardbell (More info?)
Have a K63 350 & a K63 450 cpu. Both were used in PowerLeap adapters for
separate PB systems. Also have MrBios bios upgrade for PB 680-685 series
motherboards. The bios upgrade is applicable to some other Pentium
motherboards with onboard video as well, and necessary to run these chips.
Also have 2 PL K63 adapters. All will be going up on ebay unless someone is
interested prior. K63 450 has been run underclocked at 400 & 350 has been
run at 366. Both have been rock solid stable since purchased new. Also
parting out 2 Pentium PB's. Have desktop case & "pizza box" case. Good
power supplies (145w & 235w), motherboards and 256m of ram. (8 32m chips)
56k v90 modem/soundcard and hd w/98 already loaded too. Restore disks, PCI
video cards VooDoo3 2000 16m & VooDoo5 5500 64m. All or parts.
I do not know how you can make the statement that the MR BIOS upgrade is
applicable to
some other pentium systems.
If was my understanding that this upgrade was only for the system listed.
Unless you have an upgrade that only writes to the memory address where the
particular
upgrade information is needed and that it is the same on each 2mb chip than
you are looking
for some complaints assuming there is such an upgrade .
Now the upgrade may work on some NEC systems that use the 680 MB
In any case
Ebay is the place to sell these items
"tonersniffer" <docutek@nospam.techemail.com> wrote in message
news:-pydneWZBZxj8GDfRVn-tw@comcast.com...
> is interested prior. K63 450 has been run underclocked at 400 & 350 has
> been run at 366. Both have been rock solid stable since purchased new.
> Also parting out 2 Pentium PB's. Have desktop case & "pizza box" case.
> Good power supplies (145w & 235w), motherboards and 256m of ram. (8 32m
> chips) 56k v90 modem/soundcard and hd w/98 already loaded too. Restore
> disks, PCI video cards VooDoo3 2000 16m & VooDoo5 5500 64m. All or parts.
This is copied from the readme file on the bios flash disk.
MR BIOS Version 3.46
Part Number V09AB5NV
V09AB5NV.BIO is compatible with the following motherboards:
Packard Bell, NEC, Dell "VX" with Virge S3 Trio 64+ On-Board Video
Copyright (c) 1998, Microid Research, Inc.
I didn't remember which ones at the time of my original post, but I did
remember seeing it was compatible with other mb's, fwiw. I know people have
asked about it in the past.
"metronid" <metronid@comcast.net> wrote in message
news
6adnXMQbLR8jZjeRVn-ig@comcast.com...
>applicable to
> the particular
> than you are looking
> In any case
>> chips. Also have 2 PL K63 adapters. All will be going up on ebay unless
>> someone is interested prior. K63 450 has been run underclocked at 400 &
>> 350 has been run at 366. Both have been rock solid stable since
>> purchased new. Also parting out 2 Pentium PB's. Have desktop case &
>> "pizza box" case. Good power supplies (145w & 235w), motherboards and
>> 256m of ram. (8 32m chips) 56k v90 modem/soundcard and hd w/98 already
>> loaded too. Restore disks, PCI video cards VooDoo3 2000 16m & VooDoo5
IIRC, all of the "boards" mentioned are one and the same, made by Intel
variously for PB, NEC, and Dell. The key here is the original Intel BIOS
identifier. Microid, like all the other 3rd party BIOS manufacturers now
deceased, developed one BIOS per model of motherboard.
To make a blanket statement that the BIOS can be used in other motherboards
without sufficient qualification could set up the potential naive BIOS flasher
for a disaster... Ben Myers
On Fri, 19 Aug 2005 01:26:53 -0400, "tonersniffer"
>news
>>applicable to
>> the particular
>> In any case
That is the key
Just saying for other pentium motherboards is not the key
The bios says > Packard Bell, NEC, Dell "VX" with Virge S3 Trio 64+ On-Board
Video
Saying some other motherboards with on board video is not concise enough
I would hate to see a bios screw up since there are probably quite a few
with the S3 tri ,I suppose.
My main point actually was
Sell on Ebay not on this Newsgroup
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:4305deb7.3410852@nntp.charter.net...
> motherboards
> flasher
>>have
>>news
>>>applicable to
>>> listed.
>>> the particular
>>> In any case
>>>> for
>>>> series
>>>> unless
Oh, let him try to sell it here, too. This stuff has little value any more,
except for collectors, hobbyists, and people who simply want to keep an old
system running... Ben Myers
On Fri, 19 Aug 2005 10:07:11 -0400, "metronid" <metronid@comcast.net> wrote:
>That is the key
>Video
>> motherboards
>> flasher
>>>have
>>>news
>>>>applicable to
>>>> listed.
>>>> the particular
>>>> In any case
>>>>> for
>>>>> series
>>>>> unless
He can sell it here
You are right
I just think he can do much better on Ebay
I do good there
news:43065ca0.2038484@nntp.charter.net...
> more,
> old
> wrote:
>>That is the key
>>On-Board
>>Video
>>> BIOS
>>> now
>>> motherboards
>>> flasher
>>>>have
>>>>news
>>>>>is
>>>>>applicable to
>>>>> listed.
>>>>> where
>>>>> the particular
>>>>> In any case
>>>>>> for
>>>>>> series
>>>>>> unless
>>>>>> 400
>>>>>> already
>>>>>> VooDoo5
Me too, with the right stuff... Ben
On Fri, 19 Aug 2005 21:25:09 -0400, "metronid" <metronid@comcast.net> wrote:
>He can sell it here
>You are right
>I do good there
>> more,
>> old
>> wrote:
>>>That is the key
>>>On-Board
>>>Video
>>>> BIOS
>>>> now
>>>> motherboards
>>>> flasher
>>>>>have
>>>>>news
>>>>>>is
>>>>>>applicable to
>>>>>> listed.
>>>>>> where
>>>>>> the particular
>>>>>> In any case
>>>>>>> for
>>>>>>> series
>>>>>>> unless
>>>>>>> 400
>>>>>>> already
>>>>>>> VooDoo5
Jeez. Try to share some info for Packard Bell pc parts, and you two are
gonna gang up on me for doing so? Yeah, maybe there wasn't enough info
initially, since I hadn't read the damn file for 4 or 5 years. This is the
PackardBell newsgroup, right? Don't you think most of the people who read
posts in this group have the intelligence to ask questions and read
instructions? Worked for me. I have posted help in the past in this ng. I
don't claim to be an expert, but I'm not stupid either. I have also bought
things from some posters to this group. Just trying to remove some clutter.
Get a life.
news:4306881d.13173661@nntp.charter.net...
> wrote:
>>He can sell it here
>>You are right
>>I do good there
>>> more,
>>> old
>>> wrote:
>>>>That is the key
>>>>On-Board
>>>>Video
>>>>> Intel
>>>>> BIOS
>>>>> now
>>>>> motherboards
>>>>> flasher
>>>>>> did
>>>>>>people
>>>>>>have
>>>>>>news
>>>>>>>upgrade
>>>>>>>is
>>>>>>>applicable to
>>>>>>> listed.
>>>>>>> where
>>>>>>> the particular
>>>>>>> chip
>>>>>>> In any case
>>>>>>>> adapters
>>>>>>>> for
>>>>>>>> series
>>>>>>>> unless
>>>>>>>> 400
>>>>>>>> and
>>>>>>>> already
>>>>>>>> VooDoo5
Stonersiffer
You are OK in my book
Your info was actually good
It opened up a whole new set of info from Ben about IIRC
New knowledge was exchanged
New knowledge was utilized
I do not feel that you are stupid
In fact I think your post shows that you are very intelligent
You have some great stuff
You can sell it here as far as i am concerned
This group needs some more posting and you have helped
The Bay thing
Damm I could make a very quick and profitable sale with the HW that you hace
acquired
I hope you can sell it with luck
news:isidndg3rLWhbZreRVn-3w@comcast.com...
> the PackardBell newsgroup, right? Don't you think most of the people who
> read posts in this group have the intelligence to ask questions and read
> I don't claim to be an expert, but I'm not stupid either. I have also
> bought things from some posters to this group. Just trying to remove some
> clutter. Get a life.
>> wrote:
>>>He can sell it here
>>>You are right
>>>I do good there
>>>> more,
>>>> old
>>>> wrote:
>>>>>That is the key
>>>>>On-Board
>>>>>Video
>>>>>enough
>>>>>few
>>>>>> Intel
>>>>>> BIOS
>>>>>> now
>>>>>> motherboards
>>>>>> BIOS
>>>>>> flasher
>>>>>>> did
>>>>>>>people
>>>>>>>have
>>>>>>>news
>>>>>>>>upgrade
>>>>>>>>is
>>>>>>>>applicable to
>>>>>>>> listed.
>>>>>>>> where
>>>>>>>> the particular
>>>>>>>> chip
>>>>>>>> In any case
>>>>>>>>> adapters
>>>>>>>>> for
>>>>>>>>> series
>>>>>>>>> Pentium
>>>>>>>>> these
>>>>>>>>> unless
>>>>>>>>> 400
>>>>>>>>> and
>>>>>>>>> already
>>>>>>>>> VooDoo5
news:48mdnYc5E9HVnZTeRVn-1g@comcast.com...
> Stonersiffer
> The Bay thing
> hace acquired
Actually the poster was within the meaning of the newsgroup. He was selling
or offering PB parts as a private sale. Its the stupid spammers that come
here that cause the most problems. As I went after that jerk who was posting
in French last week. Its nice to see posts here again.
Elector
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
