Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
"eagle61" <m@m.com> wrote in message
news:rAzfd.6883$rs5.548845@news20.bellglobal.com...
> oiled it, cleaned it, worked for a couple of months, on its last legs now
> still the questions stands - is ther a way to fake radeon card into
> thinking
> that fan is attached while it is not?
> <borolad@myowseintheboro.org> wrote in message
> news:rcetn09bb6mnem0acu8uuc02nb262ft1p0@4ax.com...
>> On Tue, 26 Oct 2004 21:09:34 +0100, "Warty" <yesbut@nobut.com> wrote:
>> >I'm not bloody surprised,
>> >To have no fan working on the 9700pro is instant death.
>> >Get a replacement as soon as or go for a Zalman ZM80D-HP @
>> >http://www.zalman.co.kr/
>> >What do you mean by replacing with a resistor????
>> >The fan comes away by squeezing the plastic retainer clips and she
>> >should
>> >pop away easy.
>> >Warty
>> >news:WIxfd.6799$rs5.533265@news20.bellglobal.com...
>> >> My fan is dying, but when I disconnect it the card doesn't pass the
> post.
>> It may sadly be too late M8, hope not 4 your sake -see below !
>> >> Is there a way to disconnect the fan completely from the card? mabe
>> >> replace
>> >> it by a resistor?
>> You are worried, concerned and talking shite !
>> >> I'm thinking about either mounting a bigger heatsink, or installing a
>> >> separate fan powered by the power supply - but the card doesn't want
>> >> to
>> >> pass the post with internal fan disconnected
>> Many solution
to the Tachy - fix the cooling first then - get back
>> and ask.
>> >> please help
>> Warty's right, do something about it.
>> - completely switch off from mains supply, wait 5 minutes
>> - then take out the card
>> - then unscrew the x4 little black screws
>> - remove the fan
>> - turn it upside down
>> - peel back the [ corner of ] the little white sticker
>> - then oil it with [ a very little - sewing machine type ] light oil
>> - then rotate L & R, and replace the sticker
>> - then replace!
>> Remove the [ shite & fluff ] quilt from the heatsink or it will
>> stop working again.
>> Do not use WD40 !
>> BoroLad
Attach a new ah heck
