G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I have an ATI Radeon 9800 XT Pro (128MB). I've tried fresh installs of
Windows XP and Windows 2000. Other information:
Pentium 4-2GHz
P4S5A/DX motherboard
1x256MB RAM, 1x512MB RAM
40 Gig hard disk
Soundblaster Live! 5.1
Surecom Ethernet card
I used to have a GeForce 4 Ti 4200 that worked flawlessly.
I've installed the drivers from the CD that came with it. (ATI_032403J)
It recognizes WinXP as Windows 2000, incidentally. Chipset 1039:0646
rev. 0.
The CD installs 'Radeon Display Driver', 'Control Panel' and 'Hydravision'
I get the following message on boot:
Hydravision:
'ATI's desktop manager is being unloaded because an ATI display driver
is not currently running... etc'
If I try to directly run Hydravision, I get: "This message has appeared
to inform you that Hydravision will only run when an ATI display driver
is loaded. An ATI display driver is not currently detected on your
system."
My Display properties sees Radeon 9800 Pro and Radeon 9800 Pro -
Secondary, and can display high resolutions at True Colour. The display
is obviously being accelerated. Add or Remove Programs shows ATI
Display Driver installed, Hydravision, and ATI Control Panel installed.
- If I attempt to install drivers from powercolor.com.tw (instead of the
reference CD) on a vanilla Windows XP, I get the same errors.
- Device Manager sees both display adapters properly and they appear to
work.
- I occasionally get power failure on bootup as described in my previous
email. I swear the plug is in the socket.
- S-video out does not work at all, (even when I forcibly install the
control centre and then force it to detect my TV and click the little
thing in the top left corner and select PAL B etc...). It CAN do DVI
and VGA output simultaneously.
- I didn't get an S-video to Composite converter in my box, which I
believe I should have got.
- I've plugged in my old GeForce and uninstalled the ATI drivers and
installed the nVidia drivers again... works perfectly (albeit less
advanced than my Radeon).
Is the card sick? 2 days old, under warranty, still got the receipt.
Pentium 4-2GHz
40 Gig hard disk
rev. 0.
Hydravision:
system."
work.
