Archived from groups: microsoft.public.windowsxp.security_admin (
More info?)
hi david
thx 4 the help....i tried all tht u said..
all went fine but the log file said tht few files were inaccessible...like
"An error occurred while scanning file "C:\Documents and
Settings\Administrator\NTUSER.DAT": Access is denied." n similarly many othe
r files...
else i haven't got tht warning which i used to get till now...
so wat now?
thx for ur help
gaggan
"David H. Lipman" wrote:
> From: "gaggan" <gaggan@discussions.microsoft.com>
> | hi
> | i have windows XP SP2 os, i use AVG antivirus,spybot n adaware (all
> | freewares).i keep them updated.Whenever i use adaware for scanning my hard
> | disk AVG starts giving warning abt a trojan horse ISTbar. but it is not able
> | to fix up the problem.I've tried many things including trying to delete its
> | entry keys in registry but to no avail.Kindly help me to fix the problem
> | thx
> | gaggan
> If you don't have Ad-aware SE v1.05 download it.
> Otherwise follow the instructions for its use below.
> Dump the contents of the IE Temporary Internet Folder cache (TIF)
> start --> settings --> control panel --> internet options --> delete files
> 1) Download the following three items...
> Trend Sysclean Package
http://www.trendmicro.com/download/dcs.asp
> Latest Trend Pattern File.
http://www.trendmicro.com/download/pattern.asp
> Ad-aware SE (free personal version v1.05)
> http://www.lavasoftusa.com/
> Trend Sysclean Method 1
> Create a directory.
> On drive "C:\"
> (e.g., "c:\sysclean")
> Download SYSCLEAN.COM and place it in that directory.
> Download the signature files (pattern files) by obtaining the ZIP file.
> For example; lpt556.zip
> Extract the contents of the ZIP file and place the contents in the same directory as
> SYSCLEAN.COM.
> Trend Sysclean Method 2
> The utility SYSCLEAN_FE in "Procedure 1" at the following URL
http://www.ik-cs.com/got-a-virus.htm automates the download and execution process of the
> Trend Sysclean Package.
> 2) Update Ad-aware with the latest definitions.
> 3) Disable System Restore
http://vil.nai.com/vil/SystemHelpDocs/DisableSysRestore.htm
> 4) Reboot your PC into Safe Mode and shutdown as many applications as possible
> 5) Using both the Trend Sysclean utility and Ad-aware, perform a Full Scan of your
> platform and clean/delete any infectors/parasites found.
> (a few cycles may be needed)
> 6) Restart your PC and perform a "final" Full Scan of your platform using both the
> Trend Sysclean utility and Adaware
> 7) Re-enable System Restore and re-apply any System Restore preferences,
> (e.g. HD space to use suggested 400 ~ 600MB),
> 8) Reboot your PC.
> 9) Create a new Restore point
> * Please report back your results ! *
> Dave
http://www.claymania.com/removal-trojan-adware.html
