G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
I noticed my system slowing down recently. I have NAV & Firewall, Adaware and
the betaversion of MS anti spyware all of which are kept up to date and none
of which indicated any virus problems.
As a further check I tried running Trend Sysclean. I downloaded Sysclean and
the latest pattern files but when I tried to run the .bat file I got a bloack
DOS type screen with the message “Sysclean\pattern.txt not opened for READ,
error code [0].� In attempting to close the DOS type window it restarted my
computer.
I then tried to run Trend Housecall on line checker. It gets past the first
page indicating the all is OK but when I click to proceed it goes to the
second page and hangs. In the bar at the bottom of IE it says “Applet
HCClient notinited� and in a grey box in the middle of the page it says
“Control exception: Access denied (java.util.PropertyPermis……… the rest can’t
be seen.
Sometimes when I start up I get the "New hardware Found" dialogue for no
apparant reason.
I have plenty of disk space and regularly defrag and do a general clean-up.
My WinXP is also fully up to date.
Has anybody else had such a problem?
Any help would be appreciated.
computer.
be seen.
apparant reason.
