9800 Power Connection... Okay to Daisy-chain?
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
My DVD burner started acting up and I found the only way to make use of it
was to plug it into the power cord that branches out of my 9800 pro. The
system seems stable and I'm guessing this'll be okay so long as I never try
to play Doom 3 and burn a DVD at the same time.
Anyone have any experience with this?
TIA
BAMMO
3 answers Last reply
More about 9800 power connection daisy chain
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    > try to play Doom 3 and burn a DVD at the same time.
    Should be fine as long as the cables are heavy enough to carry the current.
    If you take the power supply apart you'll find that all the cables are
    terminated to the same traces--there aren't separate supplies feeding each
    cable or anything.
    > TIA
    > BAMMO
    --John
    Reply to jclarke at ae tee tee global dot net
    (was jclarke at eye bee em dot net)
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I'm daisy chaining mine off the one that runs the HDD.
    Conor
    Opinions personal, facts suspect.
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    The HDD/FDD connectors are specified for up to 10 amps,the wires 16 amps.
    However,at least the 9500/9700 series is very sensible to line noise,which can
    be caused by drive servos.(will cause screen fuzzyness)
Radeon Connection DVD Burner Power Graphics
