Problem with still photo capture on DV camera
Last response: in Computer Peripherals
Archived from groups: alt.comp.periphs.dcameras (More info?)
I recently bought a JVC GR-DV800U DV camcorder. It also has a still photo
mode at maximum 1600x1200 resolution. Problem is, I cannot get any software
to pull the photos off at the right resolution. They all think I'm trying
to capture it as video so the resolution is usually poor. The Windows XP
interface is completely useless and doesn't even see the files half the
time, and when it does it also thinks I'm wanting to capture them from
video.
The only luck I've had was using a friend's Palm Pilot, which was able to
read my SD card and retrieve the 1600x1200x24 resolution photos. So I at
least know it is taking them at the resolution it claims it can.
Am I being forced into getting a card reader just to retrieve the photos at
the proper resolution? Is there any software that will actually retrieve
them correctly? The software that came with the camera certainly doesn't
accomplish this.
TIA
On Sun, 04 Apr 2004 19:15:32 GMT, Phil <philh69@comcast.net> was
understood to have stated the following:
>video.
>accomplish this.
I have no clue about this particular model, but I'm curious: does it
show up as a mass storage device when you plug it into the computer?
If so, you can use Explorer to copy the image files to the proper
location on your hard drive without having to purchase a card reader.
That being said, however, I find it extremely handy to have a Lexar
Media JumpDrive Trio (available from, of all places, Wal-Mart for $20)
in my pocket. This allows me to move files between the SD cards I tote
around for my camera and PDA.
"David W. Poole, Jr."
<DeadSpammersAreGoodSpammers.20.dwpj65@spamgourmet.com> wrote in
news:cal170trtcnrha2vhdkvfsf3gf3mglqall@4ax.com:
>>photo mode at maximum 1600x1200 resolution. Problem is, I cannot get
>>any software to pull the photos off at the right resolution. They all
>>think I'm trying to capture it as video so the resolution is usually
>>poor. The Windows XP interface is completely useless and doesn't even
>>see the files half the time, and when it does it also thinks I'm
>>wanting to capture them from video.
No, I don't think it sees it as a mass storage device.
When I run it through the firewire it shows up on My Computer as "AVC
Compliant DV Camcorder" I can right click and "Get Pictures" but it doesn't
show them in a list. It will show a preview of whatever picture is being
displayed on the camera at the time, and I can click "Take Picture" which
will produce a 720x480 still image. That happens to be the video resolution
of the camera. Granted it's not bad quality, but it's not the right
resolution, either.
Unfortunately the USB card readers I've seen are all USB 2.0, which I don't
have yet. I'm not familiar with the JumpDrive but I might look into it.
On Mon, 05 Apr 2004 08:43:43 GMT, Phil <philh69@comcast.net> was
Wow; I thought all cameras did this these days. I guess that's what I
get for thinking. :-/
>resolution, either.
Does the camera have a USB interface? The only DV I've messed with so
far has both the firewire and USB interface. It's been a few months,
but I believe he needed to hook the thing to his PC using both cables
for different reasons.
Unless there are issues with your system, you can pick up USB 2.0 card
pretty cheap. Plus, I *thought* that USB 2.0 devices were backward
compatible with 1.1, so you could hook up a 2.0 device to a 1.1 port,
although naturally with a degradation in throughput.
The Trio is a smallish device, large enough to hold a MMC, SD, or MS
card, and it's very handy. It's about the size of a cigarette lighter.
I keep one card in my PDA, one card in my camera, and one card in the
Trio, so I can pull images and other files when I'm around a USB
equipped PC, without having to tote cables.
Related ressources
"Phil" <philh69@comcast.net> wrote in message
news:Xns94C2119D1476philh@63.240.76.16...
doesn't
resolution
> resolution, either.
don't
The USB 2.0 card reader should be backwards compatible to be used in a USB 1
port.
news:f5o270587bkl33j6fpe9hdkho4hf8onq7g@4ax.com:
Hold that thought! :)
You are absolutely right. It does have a USB interface, I just hadn't been
using it because I was under the impression that the firewire interface was
superior. As soon as I hooked it up via USB, XP detected it and now on My
Computer it shows up as Removable Drive G, where I can easily retrieve the
photos at the proper resolution.:)  I just didn't think about the
possibility that it might interact with it differently via USB
Thanks for pointing me in the right direction!
On Mon, 05 Apr 2004 20:30:11 GMT, Phil <philh69@comcast.net> was
I'll try. :-D
Fantastic! I'm glad it's working for you. I'm also grateful to know
that the FireWire and USB interfaces work differently. Not that I'm
glad they work differently; just glad to know that they do work
differently. I'll try this if I ever encounter a similar scenario
again. It's kinda disappointing, IMO, that the USB & Firewire
interfaces for the device behave differently, given how much greater
bandwidth is available via FireWire.
Still, though, depending on your needs, that JumpDrive is a lot easier
to tote around than the cable, as it fits in your pocket so well.
Though I keep my USB cable in the bag, it's so much easier and quicker
to pull the card from the camera or PDA and slap it into the thumb
drive than it is to unwrap the cable and connect it up.
Glad it worked. Happy 'graphing!
Ask the community
