G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
When I'm watching TV (using the coax input) my sound is ok. If I start
capturing, the sound is still fine, but if I play the file later the volume
varies greatly. I almost have to constantly adjust the volume every 10
seconds or so. I've changed the quality settings, made sure nothing else
was running at the time, but nothing seems to effect it. Has anyone else
run into this problem? Thank you.
