G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Installed the new 4.11 drivers and the Catalyst Control Center booted
up with no problems. Now, when I try to boot it up it simply doesn't
work. Tried booting it from the tray, Windows start menu and the
shortcut. Nothing happens. Any ideas? Problem with all this is that
the display settings in the control panel are pure vanilla. Can't
change much more than color depth or resolution.
Remove 24 to reply.
Remove 24 to reply.
