Admin Rights Problem
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
Hi folks,
My system: Win XP Pro SP2, Standalone computer, I'm the admin.
Here is the situation: When I sign on as as a user with full admin
rights I am unable to do a direct export with my bibliographic program
(EndNote), which is one issue. Additionally, when I attempt to use
Citrix to sign on to my work (HTTS), I get a "ICA file not found." I
am told it is a problem with MS XP Pro but can't find a KB article
about it or how to fix it. If I check my rights/permissions, by all
indications it appears to be full and I am a member of the
Administrators group. I've tried everything to fix it and it is
driving me nut!!!
However, if I sign on as the administrator or create a "new" user with
full admin rights, everything works fine. So my only options, unless I
can get this fixed is to sign on under admin etc to use Citrix and/or
EndNote or try and copy my files to a new profile, which I have never
done before.
I have MS Win XP Pro's "Resource Kit Documentation" and have tried a
few things to cure the problem, but no can do.
Help!!!
Thanks in advance for any help you can give.
James Johnson
_______________
JP Johnson
7 answers Last reply
More about admin rights problem
  1. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    In news:p43371lfuq8ga5lnltpged3ierupmbnijl@4ax.com,
    JP Johnson <jpjohn19@charter.net> had this to say:
    My reply is at the bottom of your sent message:
    > Hi folks,
    > driving me nut!!!
    > done before.
    > Help!!!
    > James Johnson
    > _______________
    > JP Johnson
    Try this:
    305506 - How to Identify a Damaged User Profile and Create a New Profile:
    http://support.microsoft.com/default.aspx?scid=kb;en-us;305506
    Galen
    "My mind rebels at stagnation. Give me problems, give me work, give me
    the most abstruse cryptogram or the most intricate analysis, and I am
    in my own proper atmosphere. I can dispense then with artificial
    stimulants. But I abhor the dull routine of existence. I crave for
    mental exaltation." -- Sherlock Holmes
  2. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Thanks Galen,
    Unfortunately, the option to copy is grayed out, so it won't allow me
    to do it. But I appreciate the information, helps me to know it is
    there and I'm exploring the issues still.
    JP
    On Thu, 28 Apr 2005 23:23:03 -0400, "Galen" <galennews@gmail.com>
    >> Hi folks,
    >> driving me nut!!!
    >> done before.
    >> Help!!!
    >> James Johnson
    >> _______________
    >> JP Johnson
    >Try this:
    >Galen
    _______________
    JP Johnson
  3. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    In news:i0p771diuij8rmqjfm10dm9gcqr7uesghh@4ax.com,
    > Thanks Galen,
    How to Take Ownership of a File or Folder in Windows XP
    http://support.microsoft.com/kb/308421
    Galen
  4. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    With Galen's help, what I have discovered is that my user profile is
    probably damaged. When I created another user it solved the problems I
    had in my first thread. However, my new user profile does not have MS
    Office, Outlook, my PDA information, and some other programs.
    I assume I have to re-install all the programs that were not installed
    under "All Users." Is there a way to just copy programs to a new users
    without copying the damaged portions of the profile?
    On Sun, 1 May 2005 21:37:16 -0400, "Galen" <galennews@gmail.com>
    >> Thanks Galen,
    >Galen
    _______________
    JP Johnson
  5. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    In news:6ugn71918nasqgslpiiftachasuq8rlkve@4ax.com,
    It's not that bad nor difficult...
    Galen
    "And that recommendation, with the exaggerated estimate of my ability
    with which he prefaced it, was, if you will believe me, Watson, the
    very first thing which ever made me feel that a profession might be
    made out of what had up to that time been the merest hobby."
    Sherlock Holmes
  6. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Don't ya just love em!
    Well, it worked coping to a new profile. Unfortunately it copies
    whatever errors are causing the problems. So I guess I'm back to
    square one! But I will have to say, I'm learning a lot!
    So maybe the only option is starting with a fresh profile, adding
    things like My Documents, MS Office, Palm programs, etc. one at a
    time.
    BTW is Windows XPZ coming out anytime soon?
    On Fri, 6 May 2005 17:59:33 -0400, "Galen" <galennews@gmail.com>
    >Galen
    _______________
    JP Johnson
  7. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    You might want to try this approach:
    http://support.microsoft.com/kb/811151
    As long as you leave out ntuser.dat, ntuser.ini and
    ntuser.dat.log you should get the items you're looking to
    salvage.
    Nepatsfan
    "JP Johnson" <jpjohn19@charter.net> wrote in message
    news:qgco71laqv6lp8blfuq141mr5ub9ek19co@4ax.com...
    > copies
    > to
    > adding
    > a
    > time.
    >>> profile is
    >>> problems I
    >>> have MS
    >>> installed
    >>> new users
    >>New Profile:
    >>Galen
    > _______________
    > JP Johnson
Windows XP
