CD Key Problems
Forum Windows XP : Windows XP General Discussion - CD Key Problems
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
i currently need to activate my windows xp home edition i have until the end
of the month
the problem is i have an Windows XP Home Edition emachines key and when i
bought my new mobo and cpu two days ago, when i ran windows xp it wouldnt
work properly
because emachines makes there products impossible to change i had to
reformat my hdd
so right now i have a windows xp key thats valid and i paid for but the
non-emachine versions of windows doesnt support it so what i need is to
activate windows and change the cd key i installed it with to my emachines cd
key - which is probably impossible
or get a cd key from microsoft or emachines in exchange for the key i have
any ideas
the key i used in installation was my cousins - i understand i cant activate
that key and i really dont want to reinstall windows in 30 days any
suggestions?
Sponsored Links
and i do know i can buy an upgrade for $160 dollars canadian, but i do have a
valid windows xp key its just registered to use an emachines version of
windows xp home
Reply to Anonymous
> the end of the month
> when i bought my new mobo and cpu two days ago, when i ran windows xp
> it wouldnt work properly
> reformat my hdd
> the non-emachine versions of windows doesnt support it so what i need
> is to activate windows and change the cd key i installed it with to
> my emachines cd key - which is probably impossible
> have
> any ideas
> activate that key and i really dont want to reinstall windows in 30
> days any suggestions?
Purchase your own copy of Windows XP and perform a repair install to enter
your key.
Unfortunately for you, when you changed your motherboard, your OEM
(motherboard specific probably) copy of Windows XP became difficult to
install.
If it is actually an Install CD and not an image - it may be possible to fix
the CD to work again, but it would take some experience modifying the CD.
Truth of the matter - you could probably activate over the Internet right
now. You'd be breaking the EULA agreement.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
Reply to Anonymous
If Windows XP was preinstalled by eMachine and you
did not replace the defective motherboard with the exact
eMachine replacement, your eMachine version of Windows
XP is not going to activate since it is looking for the same BIOS.
All you can do is to purchase a conventional "Full Version" of
Windows XP and proceed with a "Repair Install".
A preinstalled OEM version of Windows XP cannot be used
with a different type of motherboard. The license is tied to
a specific motherboard model and BIOS and cannot be transferred.
Changing a Motherboard or Moving a Hard Drive with XP Installed
http://www.michaelstevenstech.com/moving_xp.html
How to Perform a Windows XP Repair Install
http://www.michaelstevenstech.­co [...] nstall.htm
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Get Windows XP Service Pack 2 with Advanced Security Technologies:
http://www.microsoft.com/athome/se [...] hoose.mspx
| of the month
| work properly
| reformat my hdd
| any ideas
| suggestions?
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0517-6, 04/30/2005
Tested on: 5/1/2005 3:35:40 PM
avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
Reply to Anonymous
I think it stinks, but unfortunately for you and others, an OEM version of
XP is permanently tied to the first machine (motherboard) originally
installed - when the machine (motherboard) dies, XP dies, unless you can get
an exact/compatible replacement motherboard from the manufacturer or the
manufacturer will supply a new CD BIOS locked to you new motherboard, you
only have one option - but an XP full version and do a repair install. Yes,
an upgrade will get you by this time, but what about next time, when you
format and want to do a clean install? You'll need some type of qualifying
media for the upgrade version to work - an old Win9x will do if you have
one, but otherwise, it'll be a hassle.
Star Fleet Admiral Q @ your Service!
http://www.google.com
Google is your "Friend"
"jamiecccp" <jamiecccp@discussions.microsoft.com> wrote in message
news:8265ECAE-5D88-4803-B144-3E5319F13621@microsoft.com...
>end
> of the month
> work properly
> reformat my hdd
> cd
> any ideas
> activate
> suggestions?
Reply to Anonymous
i'm just a little mad that my cd key is invalid
thanks for the help
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > CD Key Problems
There are 1182 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
