Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
"Doug Miannay" <dmiannayREMOVE_THIS@bellsouth.net> wrote in message
news:5O2dnYSG19fUsybcRVn-3Q@adelphia.com...
> Thanks for your efforts T Shadow!
> You will see a response by "Jack" in this thread that implies you don't
need
> to attach a cable to JP3. Instead he just connects the video camera audio
> out cable to the sound card audio in jack and it works fine for him.
> Problem here is that the camera has one of those single cable connector
> plugs the attaches to the camera's single output port and then divides
into
> a single video RCA jack and a single audio RCA jack. When both RCA jacks
> are connected to the ATI adapter cable we get no sound. Maybe if I
connect
> the camera video out RCA jack to the ATI adapter and the camera audio out
> RCA jack to the sound card audio in connector it will work. I'll have to
> give it a try.
> Doug
> "T Shadow" <knone@zilch.com.invalid> wrote in message
> news:O2uud.59835$MG3.59442@fe2.columbus.rr.com...
> > news:0sydnUkj7qz-BircRVn-jw@adelphia.com...
> >> Thanks, T Shadow, for the response!
> >> The PC has on-board sound (no PCI card) so I'd have to run a cable from
> > the
> >> 9600 to the "Aux In" connector on the motherboard. Problem is the male
> >> "Audio Out" connector on the 9600 is an odd size and clearly different
> > from
> >> the femaile connector that plugs into the motherboard. I'll obviously
> > need
> >> a cable with two different connectors to make this work.
> >> I look forward to hearing back from you after your visit to CompUSA on
> >> Thursday!
> >> Thanks again!
> >> Doug
> >> news:MQLtd.19503$4m5.15044@fe1.columbus.rr.com...
> >> > news:F4mdnQr2pOyD5ircRVn-hg@adelphia.com...
> >> >> A friend has been struggling to understand why he doesn't get the
> >> >> sound
> >> > when
> >> >> trying to capture video from an analog video camera. I went by last
> >> >> night
> >> >> to help him troubleshoot and discovered there's not a cable from the
> > AIW
> >> >> card's "audio out" connector (I believe it's labeled JP3) to the
> >> >> motherboard. I would think a cable is needed here to conduct the
> >> >> audio
> >> >> signal coming in from the video camera to the PC motherboard during
> >> > capture.
> >> >> If this is a correct assumption on my part then why didn't ATI
include
> > a
> >> >> cable in the box? The JP3 connector is also an odd size and doesn't
> > take
> >> >> the "standard" type CD audio connector either.
> >> >> The questions... does this cable need to be installed to get the
audio
> >> >> coming in through the AIW card during capture? Also, if the cable
is
> >> >> needed, where do I find one?
> >> >> Thanks!
> >> >> Doug
> >> >> Woodstock, GA
> >> > You can run the external line out on the 9600 to the external line in
> >> > on
> >> > the
> >> > sound card. Just plug it in. The initialization wizzard asks if its
> >> > connected. I don't think I got the internal cable with my AIW9600XT.
> >> > One
> >> > came with my AIW128PRO. The local Staples didn't have one. Now that
> > you've
> >> > reminded me I'll check at CompUSA tommorow. I like leaving the line
in
> > on
> >> > the sound card open.
> >> > Make sure you have the sound card recording from the port the audio
is
> >> > coming in on. Usually line in or aux.
> >> > HTH
> > The only ready made cable I could find is on the ATI website.
> > $10+shipping.
> > Ridiculess. CompUSA didn't have the cable but they do have a CD-ROM
audio
> > kit that has the connector for $4. Just a matter of cut and splicing the
> > proper connectors together. I found that I already have the connector on
a
> > cable I'm not using. Forgot, CompUSA also had an MPC-II cable ready made
> > with several connectors( including the correct ones) but its $30. Ouch!
> > Good Luck
Maybe you missed this on my first post.
>You can run the external line out on the 9600 to the external line in on
the
Look in the bundle of wires that comes out with the VGA(monitor) connectors
You will find a black phone plug. You can plug this into the sound cards
line-in. Nothing to buy. I assumed you didn't want to use it.
All you need to do it Jacks way is a phono to phone converter or cable.
