What's with the funky power cord on iPAQ 5555
Last response: in Cell Phones & Smartphones
Anonymous
April 28, 2004 1:28:56 AM
Archived from groups: microsoft.public.pocketpc (More info?)
I just upgraded from an iPAQ 3630 (dinosaur) to the h5555. When I went to
plug it in, so I could tinker with it while powering up, I discovered that
the power cord cannot connect with the device. It needs an adapter?
Anybody know what the purpose for that is? I now have four cords which are
useless unless I go buy adapters. Really bugged...
Heidi
Anonymous
April 28, 2004 1:28:57 AM
The adapter should be in the box the 5555 came in.
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Heidi Hunt" <huntesq@earthlink.net> wrote in message
news:sgAjc.12239$eZ5.2470@newsread1.news.pas.earthlink.net...
> Heidi
Anonymous
They were attempting to give you two ways too charge.
If the computer you are docking with has USB 2.0 ports then you do not need
the AC power cord plugged into it. This then allows the AC power cord when
used with the supplied adapter to be used an alternate way to charge the
device.
For those unlucky folks that are still running USB 1.0 ports they need the
AC cord to be plugged into the cradle in order to charge.
HP was simply trying to make the package contents more flexible. I agree
that they could have changed the plug on the end to one that would plug into
the cradle and the device without the adapter. My guess is that this a power
cord that they are using on other HP products.
Craig Enders
are
> Heidi
Anonymous
April 28, 2004 3:00:22 AM
The adapter is in the box. I guess my question was why it is necessary at
all. The older iPAQ's could connect directly to the power cord. The new
one has the same connector, for use when in the cradle, but the power cord
doesn't fit into it. Instead you must use the adapter with the more fragile
connector. Just doesn't seem practical.
Heidi H
"Sooner Al" <SoonerAl@somewhere.net.invalid> wrote in message
news:eFWgbEKLEHA.2488@TK2MSFTNGP10.phx.gbl...
rights...
to
that
are
> > Heidi
Anonymous
April 28, 2004 3:00:23 AM
A design issue I guess...
news:aCBjc.12358$eZ5.8731@newsread1.news.pas.earthlink.net...
> Heidi H
> rights...
> to
> that
> are
>> > Heidi
Anonymous
April 28, 2004 3:34:57 AM
Thanks, Craig. At least that is an explanation. And I can tell you from
experience that the cord IS used for other products (my old 3630 is one of
them...). However, I did not realize that I was charging while plugged into
the USB 2.0 slot, so thanks for the heads up. I will just take the adapter
home to use in the evenings!
"Craig Enders" <craigenders@hotmail.com> wrote in message
news:%23jp$%232KLEHA.2704@TK2MSFTNGP10.phx.gbl...
need
> device.
into
power
> Craig Enders
to
that
> are
> > Heidi
Anonymous
April 28, 2004 3:34:58 AM
The USB 2.0 charging needs to be activated. If I recall right the default is
off.
To activate go to Start/Settings/System/Power/USB Charging. You may need to
soft reset in order for the change to take, can't remember. I use the fast
charge. Not sure the exact difference between fast and slow, maybe someone
else can tells us.
Good luck.
Craig Enders
news:B6Cjc.12389$eZ5.2627@newsread1.news.pas.earthlink.net...
into
adapter
> need
when
> > device.
the
> into
> power
> > Craig Enders
went
> to
> that
which
> > are
> > > Heidi
Anonymous
April 28, 2004 4:23:05 AM
Wow, you were right. My default was off. I did need a soft reset, but
other than that I'm good to go.
I can't imagine what the difference between fast and slow would be, except
that my car charger is considered "fast" and my wall charger is "slow." But
when fully charged by either, the charge from the "slow" charger lasts
longer. For whatever that's worth.
Thanks for the tips!
Heidi
news:%230QdGLLLEHA.556@tk2msftngp13.phx.gbl...
is
> off.
to
> else can tells us.
> Good luck.
> Craig Enders
from
of
> into
> adapter
> > need
> when
the
> > > device.
> the
agree
plug
> > into
> > power
> > > Craig Enders
> went
> > to
discovered
> > that
> which
> > > are
> > > > Heidi
Anonymous
April 28, 2004 4:26:35 AM
Heidi,
Others have mentioned that USB charging is an issue here.
What no one has yet mentioned is that there are third party cables you might
want to look at. I just picked up a USB sync & charge cable made by Belkin
http://catalog.belkin.com/IWCatProductPage.process?Merc...
from my local Staples store for 19.95. It's wonderfully portable and, as a
nice added feature has a 'cigarette lighter' adapter which has a USB type
plug on the back half of it's face. So the cable can either be plugged in
to the USB port or into the cigarette lighter to charge your new iPaq. It
can also be used to sync as well and the end is permanent, not like the
wobbly, hope-it-holds connection between the power cord and the adapter.
I'm also a fairly recent convert from the original iPaqs. I moved up to a
5555 from a 3650 and am still using an old power cord for a spare.
Terry
are
> Heidi
Anonymous
April 28, 2004 5:13:49 AM
Extremely fragile. In fact the entire connector/cradle is really junk.
Very poor design.
Mitch
> Heidi H
Anonymous
April 28, 2004 2:46:53 PM
Hello
Do you know if this can be done on the 2210? in terms of software, as this
ipaq does not have the feature of charging from the docking station without
a power supply connected.
Thanks
Naveed
Mr Naveed Qayyum
www.mnq.org.uk
news:#0QdGLLLEHA.556@tk2msftngp13.phx.gbl...
is
> off.
to
> else can tells us.
> Good luck.
> Craig Enders
from
of
> into
> adapter
> > need
> when
the
> > > device.
> the
agree
plug
> > into
> > power
> > > Craig Enders
> went
> > to
discovered
> > that
> which
> > > are
> > > > Heidi
Anonymous
April 28, 2004 8:14:59 PM
If I recall correctly the 2210 will not charge via a USB cable. It can only
charge by using the supplied AC adapter or an equivalent aftermarket
version.
Craig Enders
"MNQ" <corlioni1976REMOVE@yahoo.co.uk> wrote in message
news:c6nulb$rr3$1@rdel.co.uk...
> Hello
without
> Thanks
> Naveed
> Mr Naveed Qayyum
> www.mnq.org.uk
default
> is
> > off.
> to
fast
someone
> > else can tells us.
> > Good luck.
> > Craig Enders
> from
one
> of
plugged
> > into
> > adapter
not
> > > need
cord
> > when
> the
> > > > device.
need
> > the
> agree
> plug
> > > into
a
> > > power
> > > > Craig Enders
> > went
> > > to
> discovered
> > > that
adapter?
> > which
> > > > are
> > > > > Heidi
April 28, 2004 9:39:27 PM
They plan use the same port for other devices, such as cameras?
