Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Problem with Microsoft USB wireless device
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Not that this is a big surprise, this piece of.....
I changed my network name and increased the WEP from 64 to 128, now the
computer that uses the USB wireless device is all messed up. I have the
MN5?? wireless 802.11b router and the matching USB wireless device.
If I go back to my main computer and display my SSID, then go back to the
computer with the USB device and UNinstall it, then reinstall it, it will
find the network and connect with "good" connection. Then I go back to my
main computer and not display my SSID and everything works, until I reboot
the computer using the wireless USB device.
I've uninstalled it, removed everything from my hard drive, but of course,
MS has decided not to allow me to remove the device info from the registry,
so every time I reinstall I have device (1), device (2), device (3) and now
device (4), all of which do not last past a single boot.
I can't use the device without the MS software because the device is only
set up for 40 & 104 bit WEP, only with the installed software can I activate
and use the 128 bit WEP on that computer.
I understand MS's need to own our computers so they can force us to continue
to with their products once we get started, but it would be nice if they
would provide me with a working device that will even 1/2 way do the trick.
Anyway, any suggestions on how to get rid of everything so that I might try
a clean install of the device and software would be helpful, or a suggestion
on how I get the device to continue to work without having to continuing to
reinstall it. Eventually I'm going to run out of device numbers.
Carol
Sponsored Links
Hi Carol,
Don't stop/hide the broadcast of the SSID on the base station.
What operating system are you using? If XP you can use native WZC to
configure the settings and don't have to run the MS Broadband Network
Utilty.
>Carol
Barb Bowman
Expert Zone Columnist
http://www.microsoft.com/windowsxp/expertzone
MS-MVP (Windows)
Reply to Anonymous
Barb, I'm running XP on all computers. I don't know what native WZC is. I
wanted to hide the SSID because I see other networks within reach and I'd
just a soon they not know I'm here too.
Carol
"Barb Bowman [MVP-Windows]" <barb@nospam.com> wrote in message
news:8gqlc0lv8d4lu8fr5o74rscqsgm8hfkqke@4ax.com...
> Hi Carol,
> Utilty.
reboot
course,
registry,
now
activate
continue
trick.
try
suggestion
to
> >Carol
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
OH... I tried to uninstall the software and set up the device using XP, but
the device will only let me use 40 or 104 bit WEP. Only with the software
can I get it to change over to 64/128. I tried it.
Carol
> Hi Carol,
> Utilty.
reboot
course,
registry,
now
activate
continue
trick.
try
suggestion
to
> >Carol
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
Carol,
Hiding the SSID broadcast won't stop someone who is determined from
sniffing out your network. Also, if you are hiding yours and someone
else is broadcasting theirs, there are issues. See
http://support.microsoft.com/defau [...] -us;811427
I've written several columns about Wireless Zero Configuration (WZC)
and there are some Cable Guy columns on the MS technet site as well
that cover this. Here's one of mine that might help you
http://www.microsoft.com/WindowsXP [...] mber16.asp
with your particular issue.
Bottom line is don't use the Broadband Network Utility that ships with
the USB wireless to configure your wireless settings. Use Windows XP.
>Carol
>> Hi Carol,
>> Utilty.
>reboot
>course,
>registry,
>now
>activate
>continue
>trick.
>try
>suggestion
>to
>> >Carol
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Reply to Anonymous
Thanks Barb,
I'm considering getting "g" router and USB adapter. My laptops are already
equipped with b/g wireless capability. The only thing that's held me back is
the fear that I'll have connection problems and not be able get everything
working. I heard some real horror stories, but it will probably resolve the
problem with the existing USB adapter I'm having the problem with. I've
heard the firewall on the mn-700 is pretty good, but is it better and easier
than the Linksys? AND I heard that MS is getting out of the networking
hardware business. That would mean that they might not be supporting it just
when I need the updates and support.
I'm going to check out your articles on the pros and cons of broadcasting, I
just thought that, as long as I'm harder to see, it makes me that much
harder to get into. I'd change my WEP periodically, but with all the problem
that is causing with the MS device, I'm leery to do so. The others were easy
because I didn't need any special software, I could just change the settings
on the wireless device settings.
I heard that Costco carries the MN-700 and USB adapter, so I may give it a
try.... reluctantly.
Thanks for you input, I really appreciate it!!
Carol
news:qgumc0loa95nsjhu34jve65j3o4nd744ks@4ax.com...
> Carol,
> >Carol
> >> Hi Carol,
> >> Utilty.
the
the
the
will
my
> >reboot
> >course,
> >registry,
and
> >now
only
> >activate
> >continue
they
> >trick.
might
> >try
> >suggestion
continuing
> >to
> >> >Carol
> >> Barb Bowman
> >> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
Microsoft IS leaving the wifi network hardware business. They've
stated there will be support for a while but if you feel you may need
a lot of official support (I've seen you recently in the dedicated
newsgroup so you already know about that) you may want to look
elsewhere. The latest version of the Linksys G router will probably be
more upgradeable and be supported longer than the MS hardware. But it
will cost more $$$.
On Sat, 12 Jun 2004 15:22:48 -0700, "Keppy" <keppy@msn.com> wrote:
>Thanks Barb,
>Carol
>> Carol,
>http://www.microsoft.com/WindowsXP/expertzone/columns/bowman/02december16.asp
>> >Carol
>> >> Hi Carol,
>> >> Utilty.
>the
>the
>the
>will
>my
>> >reboot
>> >course,
>> >registry,
>and
>> >now
>only
>> >activate
>> >continue
>they
>> >trick.
>might
>> >try
>> >suggestion
>continuing
>> >to
>> >> >Carol
>> >> Barb Bowman
>> >> MS-MVP (Windows)
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Reply to Anonymous
Thanks Barb,
By support, I really was more concerned about possible updates to fix things
that come up. For tech support I have these boards and you :-)
BTW, I didn't have WZC options on that computer with the USB adapter, I did
get it going, but still, the device itself is only capable of 40/104 bit
WEP. The setup has to be done through the BBN to be able to use 128 bit. I
may get the MN-7?? USB adapter, just so that I will have the "g" capability
AND it will have 128 bit WEP.
One more question, I enabled MAC filtering, I'm guessing that each computer
will keep the same MAC address. I guess I thought that the address might
change each time I boot the machine.
Thanks for all your help!
Carol
news:jp8oc0tc0a5tesv1n7u62ddr7ololm186f@4ax.com...
> will cost more $$$.
> >Thanks Barb,
already
is
everything
the
easier
just
broadcasting, I
problem
easy
settings
a
> >Carol
> >> Carol,
sp
is. I
I'd
> >> >Carol
> >> >> Hi Carol,
Network
> >> >> Utilty.
> >the
> >the
device.
to
> >the
it
> >will
to
> >my
> >> >reboot
> >> >course,
> >> >registry,
> >and
> >> >now
is
> >only
> >> >activate
> >> >continue
> >they
the
> >> >trick.
> >might
> >> >try
> >> >suggestion
> >continuing
> >> >to
> >> >> >Carol
> >> >> Barb Bowman
> >> >> MS-MVP (Windows)
> >> Barb Bowman
> >> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
If you are running XP SP1/1a, the key length determine the encryption
strength. MS wanted to simplify it and "just make it work" in SP1
(think of 40 and 64 as the same and 104/128 as the same)
1 ASCII Character=8 Bits
1 HEX Character=4 Bits
40 or 64 bit ASCII WEP code has 5 characters
40 or 64 bit HEX WEP code has 10 characters
104 or 128 bit ASCII WEP code has 13 characters
104 or 128 bit HEX WEP code has 26 characters
so to enable 128 bit WEP, enter 26 characters comprise of the letters
a-f and numbers 0-9
updates to fix things - MS has always been slower to release updates
than other vendors.
The MAC address of the adapters does not change.
On Sun, 13 Jun 2004 08:13:45 -0700, "Keppy" <keppy@msn.com> wrote:
>Thanks Barb,
>Carol
>> will cost more $$$.
>> >Thanks Barb,
>already
>is
>everything
>the
>easier
>just
>broadcasting, I
>problem
>easy
>settings
>a
>> >Carol
>> >> Carol,
>sp
>is. I
>I'd
>> >> >Carol
>> >> >> Hi Carol,
>Network
>> >> >> Utilty.
>> >the
>> >the
>device.
>to
>> >the
>it
>> >will
>to
>> >my
>> >> >reboot
>> >> >course,
>> >> >registry,
>> >and
>> >> >now
>is
>> >only
>> >> >activate
>> >> >continue
>> >they
>the
>> >> >trick.
>> >might
>> >> >try
>> >> >suggestion
>> >continuing
>> >> >to
>> >> >> >Carol
>> >> >> Barb Bowman
>> >> >> MS-MVP (Windows)
>> >> Barb Bowman
>> >> MS-MVP (Windows)
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Reply to Anonymous
I have 128 WEP enabled on the router and my other computers, but I wasn't
able to enter the 26 characters into the WEP key settings and there wasn't
an option for ASCII or hex. Another weird thing, After installing the WZC on
that computer (in services it said it was auto and running, but there was no
wireless tab so I added it via the INF directory) once I did that, there was
a third network icon in my system tray, one for the BBN, one just said it
was the wireless connection, I could disable it or open network connections
and the new one gives me the option to view available networks. AND if that
weren't strange enough, if I open the network connections from the icon that
only gives me the option to do so (or disable), and right click on it, there
still in NO wireless tab in the adapter properties. BUT, If I open the
network connections by right clicking on the new icon in the system tray,
the one that gives me the added option to view available networks, and right
click on the (what appears to be the same) wireless connection, it has the
wireless tab. ALSO, if I just open the network properties, say via the
control panel, or that icon that doesn't have the available networks, in the
advanced tab, the firewall in NOT enabled BUT, If I open the network
connections with the new icon and right click the (what looks to be the
same) wireless connection, and go to the advanced tab, the firewall IS
enabled. I'm so confused... now I'm guessing you are pretty confused too!
Anyway, it is working, as long as I keep my SSID broadcasting (which I still
don't like), and all my computers can share with all my computers.
I'm going to read more of your site info and see if I can learn
something.... wishful thinking.
Carol
news:phtoc0lvupaom6ppm23jphsre6thflmc1b@4ax.com...
> a-f and numbers 0-9
> than other vendors.
> >Thanks Barb,
things
did
I
capability
computer
> >Carol
> >> will cost more $$$.
> >> >Thanks Barb,
> >already
back
> >is
> >everything
resolve
> >the
I've
> >easier
networking
it
> >just
> >broadcasting, I
> >problem
were
> >easy
> >settings
it
> >a
> >> >Carol
> >> >> Carol,
someone
a
> >sp
with
XP.
> >is. I
and
> >I'd
> >> >> >Carol
> >> >> >> Hi Carol,
to
> >Network
> >> >> >> Utilty.
now
> >> >the
have
> >> >the
> >device.
back
> >to
> >> >the
it,
> >it
> >> >will
back
> >to
> >> >my
until I
> >> >> >reboot
of
> >> >> >course,
the
> >> >> >registry,
(3)
> >> >and
> >> >> >now
device
> >is
> >> >only
can I
> >> >> >activate
to
> >> >> >continue
if
> >> >they
> >the
> >> >> >trick.
I
> >> >might
> >> >> >try
a
> >> >> >suggestion
> >> >continuing
> >> >> >to
> >> >> >> >Carol
> >> >> >> Barb Bowman
> >> >> >> MS-MVP (Windows)
> >> >> Barb Bowman
> >> >> MS-MVP (Windows)
> >> Barb Bowman
> >> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
You have 3 icons:
1 is the BBN icon from the MS Software
1 is the wireless connection icon (the one that lets you view wireless
connections, etc)
1 is for a IGD (Internet Gateway Device) - i.e., the router - this is
shown because the router is UPnP.
(the last two icons look the same on SP1. in SP2, there will be a
change and these two will look different and will be less confusing)
>Carol
>> a-f and numbers 0-9
>> than other vendors.
>> >Thanks Barb,
>things
>did
>I
>capability
>computer
>> >Carol
>> >> will cost more $$$.
>> >> >Thanks Barb,
>> >already
>back
>> >is
>> >everything
>resolve
>> >the
>I've
>> >easier
>networking
>it
>> >just
>> >broadcasting, I
>> >problem
>were
>> >easy
>> >settings
>it
>> >a
>> >> >Carol
>> >> >> Carol,
>someone
>a
>> >sp
>with
>XP.
>> >is. I
>and
>> >I'd
>> >> >> >Carol
>> >> >> >> Hi Carol,
>to
>> >Network
>> >> >> >> Utilty.
>now
>> >> >the
>have
>> >> >the
>> >device.
>back
>> >to
>> >> >the
>it,
>> >it
>> >> >will
>back
>> >to
>> >> >my
>until I
>> >> >> >reboot
>of
>> >> >> >course,
>the
>> >> >> >registry,
>(3)
>> >> >and
>> >> >> >now
>device
>> >is
>> >> >only
>can I
>> >> >> >activate
>to
>> >> >> >continue
>if
>> >> >they
>> >the
>> >> >> >trick.
>I
>> >> >might
>> >> >> >try
>a
>> >> >> >suggestion
>> >> >continuing
>> >> >> >to
>> >> >> >> >Carol
>> >> >> >> Barb Bowman
>> >> >> >> MS-MVP (Windows)
>> >> >> Barb Bowman
>> >> >> MS-MVP (Windows)
>> >> Barb Bowman
>> >> MS-MVP (Windows)
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Reply to Anonymous
Of course you would know all this stuff... I don't think there is much you
haven't had a chance to deal with.
I went out today and got the 700 series router and USB adapter. Any special
instructions I should know as I'm upgrading from the 500 series. I know that
a clean install is always better, but I also know it's next to impossible to
completely uninstall this stuff. You can't even delete it from the registry.
I'm going to go over the instructions and see how helpful it is. I've got to
tell you, I'm NERVOUS!
Carol
news:64bpc091snqe2r9i10103gdlv8qhfvmt14@4ax.com...
> You have 3 icons:
> connections, etc)
wasn't
on
no
was
connections
that
that
there
right
the
the
still
> >Carol
> >> a-f and numbers 0-9
> >> than other vendors.
> >> >Thanks Barb,
> >things
I
> >did
bit
bit.
> >I
> >capability
> >computer
might
> >> >Carol
need
be
it
> >> >> will cost more $$$.
> >> >> >Thanks Barb,
> >> >already
me
> >back
> >> >is
> >> >everything
> >resolve
> >> >the
> >I've
and
> >> >easier
> >networking
supporting
> >it
> >> >just
> >> >broadcasting, I
much
the
> >> >problem
> >were
> >> >easy
> >> >settings
give
> >it
> >> >a
> >> >> >Carol
> >> >> >> Carol,
from
> >someone
(WZC)
well
> >a
> >> >sp
> >with
> >XP.
WZC
> >> >is. I
reach
> >and
> >> >I'd
> >> >> >> >Carol
> >> >> >> >> Hi Carol,
WZC
> >to
> >> >Network
> >> >> >> >> Utilty.
128,
> >now
> >> >> >the
I
> >have
> >> >> >the
> >> >device.
> >back
> >> >to
> >> >> >the
> >it,
> >> >it
> >> >> >will
go
> >back
> >> >to
> >> >> >my
> >until I
> >> >> >> >reboot
but
> >of
> >> >> >> >course,
> >the
> >> >> >> >registry,
device
> >(3)
> >> >> >and
> >> >> >> >now
> >device
> >> >is
> >> >> >only
> >can I
> >> >> >> >activate
us
> >to
> >> >> >> >continue
nice
> >if
> >> >> >they
do
> >> >the
> >> >> >> >trick.
that
> >I
> >> >> >might
> >> >> >> >try
or
> >a
> >> >> >> >suggestion
> >> >> >continuing
> >> >> >> >to
numbers.
> >> >> >> >> >Carol
> >> >> >> >> Barb Bowman
> >> >> >> >> MS-MVP (Windows)
> >> >> >> Barb Bowman
> >> >> >> MS-MVP (Windows)
> >> >> Barb Bowman
> >> >> MS-MVP (Windows)
> >> Barb Bowman
> >> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
I did go to your web site and read the info you had on using both routers,
one as an access point. I decided just to replace the 500 with the 700. I
have one laptop that I think has an 802.11b but I'm not sure it isn't b/g,
none the less, I didn't want the extra stuff in my living room. My house
already looks pretty strange to most people, with all the wired and wireless
junk everywhere (not to mention my 5 computers, one not on the network) This
install was pretty painless with the router. I had a little problem with the
USB adapter because I was using the CD that came with the router and it only
had version 2.0 and didn't have the 710 even listed on it. Once I got the
other CD with version 2.1 drivers and the USB "g" drivers, I was up and
running. I know you said, and I read the stuff on none broadcasting the
SSID, but I feel a little more comfortable not broadcasting. I'm not
concerned about people driving by. I live in a pretty secluded area so I
don't really think there are going to be too many drive by scanners, but if
my "young" neighbors don't see me regularly, like I do them, I'm happier.
The new USB device seems to be working fine with the none broadcast SSID. I
did enable MAC filtering, as I read on your site.
Thanks Barb, for all your help and support. I'll tell you, we wouldn't know
what to do without you!!!
Carol
> You have 3 icons:
> connections, etc)
wasn't
on
no
was
connections
that
that
there
right
the
the
still
> >Carol
> >> a-f and numbers 0-9
> >> than other vendors.
> >> >Thanks Barb,
> >things
I
> >did
bit
bit.
> >I
> >capability
> >computer
might
> >> >Carol
need
be
it
> >> >> will cost more $$$.
> >> >> >Thanks Barb,
> >> >already
me
> >back
> >> >is
> >> >everything
> >resolve
> >> >the
> >I've
and
> >> >easier
> >networking
supporting
> >it
> >> >just
> >> >broadcasting, I
much
the
> >> >problem
> >were
> >> >easy
> >> >settings
give
> >it
> >> >a
> >> >> >Carol
> >> >> >> Carol,
from
> >someone
(WZC)
well
> >a
> >> >sp
> >with
> >XP.
WZC
> >> >is. I
reach
> >and
> >> >I'd
> >> >> >> >Carol
> >> >> >> >> Hi Carol,
WZC
> >to
> >> >Network
> >> >> >> >> Utilty.
128,
> >now
> >> >> >the
I
> >have
> >> >> >the
> >> >device.
> >back
> >> >to
> >> >> >the
> >it,
> >> >it
> >> >> >will
go
> >back
> >> >to
> >> >> >my
> >until I
> >> >> >> >reboot
but
> >of
> >> >> >> >course,
> >the
> >> >> >> >registry,
device
> >(3)
> >> >> >and
> >> >> >> >now
> >device
> >> >is
> >> >> >only
> >can I
> >> >> >> >activate
us
> >to
> >> >> >> >continue
nice
> >if
> >> >> >they
do
> >> >the
> >> >> >> >trick.
that
> >I
> >> >> >might
> >> >> >> >try
or
> >a
> >> >> >> >suggestion
> >> >> >continuing
> >> >> >> >to
numbers.
> >> >> >> >> >Carol
> >> >> >> >> Barb Bowman
> >> >> >> >> MS-MVP (Windows)
> >> >> >> Barb Bowman
> >> >> >> MS-MVP (Windows)
> >> >> Barb Bowman
> >> >> MS-MVP (Windows)
> >> Barb Bowman
> >> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
Reply to Anonymous
glad you got things running so quickly with your new hardware.
>Carol
>> You have 3 icons:
>> connections, etc)
>wasn't
>on
>no
>was
>connections
>that
>that
>there
>right
>the
>the
>still
>> >Carol
>> >> a-f and numbers 0-9
>> >> than other vendors.
>> >> >Thanks Barb,
>> >things
>I
>> >did
>bit
>bit.
>> >I
>> >capability
>> >computer
>might
>> >> >Carol
>need
>be
>it
>> >> >> will cost more $$$.
>> >> >> >Thanks Barb,
>> >> >already
>me
>> >back
>> >> >is
>> >> >everything
>> >resolve
>> >> >the
>> >I've
>and
>> >> >easier
>> >networking
>supporting
>> >it
>> >> >just
>> >> >broadcasting, I
>much
>the
>> >> >problem
>> >were
>> >> >easy
>> >> >settings
>give
>> >it
>> >> >a
>> >> >> >Carol
>> >> >> >> Carol,
>from
>> >someone
>(WZC)
>well
>> >a
>> >> >sp
>> >with
>> >XP.
>WZC
>> >> >is. I
>reach
>> >and
>> >> >I'd
>> >> >> >> >Carol
>> >> >> >> >> Hi Carol,
>WZC
>> >to
>> >> >Network
>> >> >> >> >> Utilty.
>128,
>> >now
>> >> >> >the
>I
>> >have
>> >> >> >the
>> >> >device.
>> >back
>> >> >to
>> >> >> >the
>> >it,
>> >> >it
>> >> >> >will
>go
>> >back
>> >> >to
>> >> >> >my
>> >until I
>> >> >> >> >reboot
>but
>> >of
>> >> >> >> >course,
>> >the
>> >> >> >> >registry,
>device
>> >(3)
>> >> >> >and
>> >> >> >> >now
>> >device
>> >> >is
>> >> >> >only
>> >can I
>> >> >> >> >activate
>us
>> >to
>> >> >> >> >continue
>nice
>> >if
>> >> >> >they
>do
>> >> >the
>> >> >> >> >trick.
>that
>> >I
>> >> >> >might
>> >> >> >> >try
>or
>> >a
>> >> >> >> >suggestion
>> >> >> >continuing
>> >> >> >> >to
>numbers.
>> >> >> >> >> >Carol
>> >> >> >> >> Barb Bowman
>> >> >> >> >> MS-MVP (Windows)
>> >> >> >> Barb Bowman
>> >> >> >> MS-MVP (Windows)
>> >> >> Barb Bowman
>> >> >> MS-MVP (Windows)
>> >> Barb Bowman
>> >> MS-MVP (Windows)
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Reply to Anonymous
There are 561 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
