Problem after upgrading to SP2
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
My husband finally bit the bullet and installed SP2 on his desktop. He has
run into a problem that has me stumped.
We are using a Linksys wireless router and are trying to set things up so
that everyone can see and access files & Printers on our little 4+ computer
network. We are all running XP Pro. He is wired to the router with 2
wireless laptops plus one other wired desktop.
When he upgraded to SP2 we lost the ability to connect to his computer. We
can see his computer under 'My Network Places' but we can not connect. He
CAN connect to us however but not the other way around. I disabled his
Windows Firewall the other day and I could connect to his computer. As soon
as I enable the firewall again access is blocked again. I'm stumped because
when I upgraded my laptop to SP2 I did not have to change any firewall
settings to continue to see the network including his machine.
I have compared our firewall settings and they are the same so I don't know
what setting needs to be changed at this point. And yes, file sharing is
enabled. Guest account is enabled. Simple file sharing is also enabled.
What am I missing?
TIA,
Laura
10 answers Last reply
More about problem upgrading
  1. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Check the firewall settings and ensure that File and Print Sharing are allowed as exceptions.
    Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display\Security
    Win 95/98/Me/XP Tweaks and Fixes
    http://www.dougknox.com
    Per user Group Policy Restrictions for XP Home and XP Pro
    http://www.dougknox.com/xp/utils/xp_securityconsole.htm
    Please reply only to the newsgroup so all may benefit.
    Unsolicited e-mail is not answered.
    "Laura" <invalid@sample.invalid> wrote in message news:aAlje.796514$w62.674976@bgtnsc05-news.ops.worldnet.att.net...
    > What am I missing?
    > TIA,
    > Laura
  2. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Try the following:
    Disconnect the cable from the router, unplug the power
    to the router, wait 2 minutes, reconnect the cable to the
    router, then return power to the router.
    Carey Frisch
    Microsoft MVP
    Windows XP - Shell/User
    Microsoft Newsgroups
    Get Windows XP Service Pack 2 with Advanced Security Technologies:
    http://www.microsoft.com/athome/security/protect/windowsxp/choose.mspx
    | What am I missing?
    | TIA,
    | Laura
  3. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Yes it is. That's what I meant when I said that File sharing was enabled. Or
    are there multiple places to enable file sharing?
    "Doug Knox MS-MVP" <dknox@mvps.org> wrote in message
    news:uy$dfHUXFHA.2060@tk2msftngp13.phx.gbl...
    Display\Security
    > computer
    > soon
    > because
    > know
    > What am I missing?
    > TIA,
    > Laura
  4. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Hi Laura,
    It definitely sounds like its firewall related. The following from http://www.michna.com/kb/WxSP2.htm may help.
    Firewall blocks LAN connection
    The new firewall blocks file and printer sharing and pinging by default. To allow this again, open the Windows Firewall settings in Control Panel. Use the Exceptions tab and check the File and Printer Sharing entry, which should now, by default, be set only for the local subnet, i.e. your LAN on the near side of any routers. This also reenables ping responses and allows the browser service to start. Reboot to allow the service to start or start the service by hand.
    If you want only ping responses without file and printer sharing, click on the Advanced tab, then the ICMP Settings button. Check "Allow incoming echo request".
    If, however, you need full and free communications for any type of connection, then use the third tab, Advanced, and remove the check mark from your LAN (Local Area Network) interface to allow full local connectivity for all types of traffic. This is obviously more risky and usually not necessary. Don't do it unless you are certain that all other local computers can never pose a danger. Consider that every laptop or guest computer brought into the LAN can bring a virus along.
    The better alternative is to leave the firewall enabled even for the LAN interface, i.e. for your local area network, and open only the services that are actually needed, i.e. any server functions the computer may have. Here you also have the choice to open these server functions only for the local subnet. You can also allow the first ICMP function (echo, ping) or all of them.
    "Laura" <invalid@sample.invalid> wrote in message news:v4nje.232673$cg1.156149@bgtnsc04-news.ops.worldnet.att.net...
    > Display\Security
    >> computer
    >> soon
    >> because
    >> know
    >> What am I missing?
    >> TIA,
    >> Laura
  5. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    And what is this suppose to accomplish? Will I lose all my wireless settings
    if I power down the router?
    "Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
    news:eJSMTHUXFHA.2348@TK2MSFTNGP14.phx.gbl...
    > Try the following:
    > Carey Frisch
    > Microsoft MVP
    > has
    > so
    > computer
    > We
    > He
    > soon
    > because
    > know
    > | What am I missing?
    > | TIA,
    > | Laura
  6. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    It reboots the router, like rebooting your computer. You won't lose any
    settings.
    Tom
    news:G5nje.232676$cg1.173804@bgtnsc04-news.ops.worldnet.att.net...
    settings
    | > Try the following:
    | > Carey Frisch
    | > Microsoft MVP
    | > has
    | > so
    | > computer
    computer.
    | > We
    | > He
    | > soon
    | > because
    | > know
    is
    enabled.
    | > | What am I missing?
    | > | TIA,
    | > | Laura
  7. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    news:unDTKDVXFHA.1040@TK2MSFTNGP10.phx.gbl...
    Hi Laura,
    >>>>your message is formated with Printed-quotable so the > are not getting
    >>>>set when I hit reply. See inline.
    >>>>File & printing sharing entry is checked in the exceptions tab. What's
    >>>>the browser service?
    request".
    >>>>This option is checked too. Also on my machine.
    >>>>I have left this one checked. Again, same setting on my computer
    them.
    >>>>What services do you think I would need enabled. I only want to use his
    >>>>printer at this point. My new laptop did not come with a parallel port
    >>>>so I can not hook up the printer anymore. The printer is so old (but
    >>>>still works fine) that it does not come with a USB option.
    any more thoughts?
  8. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    The Browser service is the Computer Browser service and can be found by going to Start, Run and entering SERVICES.MSC.
    Is there a particular error message when you try to connect to his computer?
    "Laura" <invalid@sample.invalid> wrote in message news:oloje.232906$cg1.59437@bgtnsc04-news.ops.worldnet.att.net...
    > Hi Laura,
    > request".
    > them.
    > any more thoughts?
  9. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Done. No change with this issue.
    "Tom Pepper Willett" <tompepper@mvps.org> wrote in message
    news:en07b%23UXFHA.2124@TK2MSFTNGP14.phx.gbl...
    > settings.
    > Tom
    > settings
    > | > Try the following:
    > | > Carey Frisch
    > | > Microsoft MVP
    > He
    > | > has
    > up
    > | > so
    > | > computer
    > computer.
    > | > We
    > connect.
    > | > He
    > his
    > As
    > | > soon
    > | > because
    > firewall
    > don't
    > | > know
    > sharing
    > is
    > enabled.
    > | > | What am I missing?
    > | > | TIA,
    > | > | Laura
  10. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    The message is:
    \\computername is not accessible. You might not have permission to use this
    network resource. Contact the administrator of thie server to find out if
    you have access permissions. The network path was not found.
    I'll check the Browser service but I can't imagine it being disabled. This
    did work prior to upgrading to SP2.
    news:%23NxbmHWXFHA.3712@TK2MSFTNGP09.phx.gbl...
    Display\Security
    > Hi Laura,
    > To
    > allows
    > start
    > echo
    > request".
    > from
    > for
    > computers
    > that
    > them.
    > any more thoughts?
Computers Windows XP
