TV sound issues (okay, let's try this again...)
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
AIW9800Pro, Catalyst 4.12 and MMC9.03, on AMD64 SIS755/964, XP SP2, 768MB,
Videologic Sonicfury or onboard AC97.
Each time I change channels on the TV app there's an irritating buzz.
Sometimes it goes away and normal sound returns, sometimes it does not go
away, sometimes all sound is lost. Whether I use the on-board AC97 sound or
the Videologic makes no difference. Whether I use an internal connection to
AUX or an external connection to line-in makes no difference.
Oh, DX9.0c, UK PAL tuner, connected to NTL cable.
(Incidentally, is there a way to force a real re-install of DX9.0c rather
than for it to just say "yep, looks like everything is okay" and not
actually do anything?)
Does anyone in the UK have Windoze Media Encoder 9 installed and still have
a working tuner?
/mel/
np: Orbital - Remind
3 answers Last reply
More about sound issues okay again
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Yip, same here, well almost....a horrid buzzing noise when changing
    channels, but it goes away after 1sec or so.
    No other problems..on my 9800...AIW
    But I'm using the Omega 4.12 drivers, although it was the same on the
    catalyst ones.
    > a working tuner?
    Yip !
    Jez
    'Realism is seductive because once you have accepted the reasonable
    notion that you should base your actions on reality, you are too often
    led to accept, without much questioning, someone else's version of what
    that reality is. It is a crucial act of independent thinking to be
    skeptical of someone else's description of reality.'-
    Howard Zinn
    NFS Underground2, Americas Army And MOH-PA
    yahoo ID: hellward2004
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Jez wrote:
    >> 768MB, Videologic Sonicfury or onboard AC97.
    >> not go away, sometimes all sound is lost. Whether I use the on-board
    >> AC97 sound or the Videologic makes no difference. Whether I use an
    >> internal connection to AUX or an external connection to line-in
    > catalyst ones.
    I'm going to try installing some older WDM drivers...
    >> rather than for it to just say "yep, looks like everything is okay"
    >> and not actually do anything?)
    >> still have a working tuner?
    > Yip !
    Really? *Encoder*, not player? Hmmm. I shall investigate further.
    /mel/
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    >>catalyst ones.
    >>Yip !
    Yeah....not that I use it much, only for encoding to WMA, but it doesn't
    effect my ATI TV prog at all.
    Jez
    Howard Zinn
Radeon TV Graphics
