Archived from groups: microsoft.public.windowsxp.security_admin (
More info?)
Had to give admin rights to the domain account for the local computer so the
security errors pop ups would stop. Power users access was not could enough
thanks for your help
Neal
"Bruce Chambers" wrote:
> NealJH wrote:
> > i am having trouble getting legacy programs to run under power users local
> > group. I am logging into a Server 2003 env. and have set the domain accounts
> > to the local power users group.
> > thanks
> You may experience some problems if the software was designed for
> Win9x/Me, or if it was intended for WinNT/2K/XP, but was improperly
> designed. Quite simply, the application doesn't "know" how to handle
> individual user profiles with differing security permissions levels, or
> the application is designed to make to make changes to "off-limits"
> sections of the Windows registry or protected Windows system folders.
> For example, saved data are often stored in a sub-folder under the
> application's folder within C:\Program Files - a place where no
> inexperienced or limited user should ever have write permissions.
> It may even be that the software requires "write" access to parts
> of the registry or protected systems folders/files that are not normally
> accessible to regular users. (This *won't* occur if the application is
> properly written.) If this does prove to be the case, however, you're
> often left with three options: Either grant the necessary users
> appropriate higher access privileges (either as Power Users or local
> administrators), explicitly grant normal users elevated privileges to
> the affected folders and/or part(s) or the registry, or replace the
> application with one that was properly designed specifically for
> WinNT/2K/XP.
> Some Programs Do Not Work If You Log On from Limited Account
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q307091
> Additionally, here are a couple of tips suggested, in a reply to a
> different post, by MS-MVP Kent W. England:
> "If your game or application works with admin accounts, but not with
> limited accounts, you can fix it to allow limited users to access the
> program files folder with "change" capability rather than "read" which
> is the default.
> C:\>cacls "Program Files\appfolder" /e /t /p users:c
> where "appfolder" is the folder where the application is installed.
> If you wish to undo these changes, then run
> C:\>cacls "Program Files\appfolder" /e /t /p users:r
> If you still have a problem with running the program or saving
> settings on limited accounts, you may need to change permissions on
> the registry keys. Run regedit.exe and go to HKLM\Software\vendor\app,
> where "vendor\app" is the key that the software vendor used for your
> specific program. Change the permissions on this key to allow Users
> full control."
> Bruce Chambers
> Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
> You can have peace. Or you can have freedom. Don't ever count on having
> both at once. - RAH
