Tom's Hardware > Forum > Graphic & Displays > ATI > Problem with Radeon 9200SE DVI -> HDMI setup
Forum Graphic & Displays : ATI - Problem with Radeon 9200SE DVI -> HDMI setup
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I'm having problems with the following setup:
Dell Intel 1.0 GHz 512MB
Windows Media Center 2004
Radeon 9200SE plugged into my Toshiba 51H84 HDTV using a DVI to HDMI cable
Catalyst 5.1 (older drivers do not perform any differently)
When I try to run the TV as the primary screen, the computer goes into a
continuous re-boot loop. I have to disconnect the DVI output and connect the
TV through an RCA video cable.
I am able to boot up using the RCA video cable, and run the TV as both
primary (through RCA 800x600) and secondary (DVI->HDMI 720p) screen.
If I try to swap screens I.e. make the DVI output primary, both screens go
black, and the computer freezes. If I force a re-start, the computer goes
into a continuous re-boot loop again.
So, I have a DVI -> HDMI connection to my TV, and it's apparently working,
just not as the primary.
Any help is appreciated.
Thanks!
Johnny
Sponsored Links
There are 1014 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
