Tom's Hardware > Forum > Graphic & Displays > ATI > Radeon 9600XT - Video Problems
Forum Graphic & Displays : ATI - Radeon 9600XT - Video Problems
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi,
I've had my oem Radeon 9600XT for about 3/4 months. Recently, I've started
to get pixilation breakup. The card is not and never has been over-clocked.
The tempreture within the case is easily within tolerance limits. I've
resolved the problem by updating the drivers / re-installing them. However,
its starting to get annoying now. There is no pattern to the problem.
Sometimes the machine can be switched off for days and the problem appears
at next start up, whereas other times it occurs with a reboot after a
Windows update, etc. Any ideas?
Blake
Sponsored Links
"Blakes7" <blakes.7@ntlworld.com> wrote in message
news:ht8Nd.532$So3.361@newsfe3-win.ntli.net...
> Hi,
> started to get pixilation breakup.
Check for proper fan speed and fan operation. If it's binding or obstructed
you can get this sort of thing. Hopefully that's all it is. Otherwise it's
RMA time.
Reply to Anonymous
Check windows update aren't putting their Radeon graphic drivers back in.
> Hi,
> started to get pixilation breakup. The card is not and never has been
> over-clocked. The tempreture within the case is easily within tolerance
> limits. I've resolved the problem by updating the drivers / re-installing
> them. However, its starting to get annoying now. There is no pattern to
> the problem. Sometimes the machine can be switched off for days and the
> problem appears at next start up, whereas other times it occurs with a
> reboot after a Windows update, etc. Any ideas?
> Blake
Reply to Anonymous
There are 1182 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
