G
Guest
Guest
Archived from groups: rec.photo.digital,alt.comp.periphs.dcameras (More info?)
Which will last longer? Rechargable AA batteries or a CRV3? My camera
is a Nikon Coolpix 3200 which ate the included AA batteries in 3 days.
Thanks.
---->Sagittaria<----
5/2/04
You'll take an inch but you'd love a mile.
G
Guest
Guest
> Thanks.
I don't quite see what you're asking..
Rechargable nickel-metal hydride batteries (NiMh) could easily last you
a year or more.. You throw non rechargable CRV3's out when they're done.
Rechargable NiMh AA's are the absolute, hands down best choice. Don't even
consider anything else.
G
Guest
Guest
Check out the battery review at
http://www.nikonians.org/html/resources/guides/ebooks/nikonians-battery-guide.html
"Sagittaria" <sagittaria@gmail.com.nospam> wrote in message
news:Xns94DDA11EA6306sagittaria@216.168.3.44...
> Thanks.
> 5/2/04
G
Guest
Guest
> Thanks.
The CRV3 will probably last about twice as long as a fully charged NIMH
battery set. On the other hand, the NIMH can be recharged 500-1000
times, and after a few charges it will last longer than it does
initially. Give them 3 or 4 recharge cycles before giving up on them.
G
Guest
Guest
Of course you could get rechargeable CR-V3s, which, in my Oly camera,
give me better performance than NiMh's, though the NiMh's are cheaper up
front and do work well. Forget Alkalines. The rechargeable ones are very
good for flashlights.
> Thanks.
G
Guest
Guest
Rechargable batteries should last significantly longer than alkaline batteries.
Read the manual.
G
Guest
Guest
Ian Stirling <root@mauve.demon.co.uk> wrote in
news:B0flc.38595$Y%6.5292497@wards.force9.net:
>> camera is a Nikon Coolpix 3200 which ate the included AA
> alkaline batteries. Read the manual.
Yes, I figured that - but I am asking about rechargable vs. Lithium
(the crv3). Anyone know? The manual says all will work in the camera,
but doesn't say anything about their lifespan.
5/2/04
G
Guest
Guest
Ok.
How many AA batteries.
CRV3 cells do around 3000mah at 3V
This is 9000mWh.
One AA NiMH cell does 1.2*2200=2700mWh.
So, for three AA cells, about the same, less than four.
All will depend on loads.
G
Guest
Guest
If you mean shelf life "last longer" typically lithium can sit for 10 years
and still be mostly charged.
"Ian Stirling" <root@mauve.demon.co.uk> wrote in message
news:Wxflc.36783$h44.5548549@stones.force9.net...
> Ok.
> This is 9000mWh.
G
Guest
Guest
> Thanks.
I've been using 4 x 2300 mAh rechargeable NiMH in my Sigma SD-10, which
otherwise needs 2 x CRv3. There is no contest; the CRV3 combo lasts
about twice the amount of shots, then dies instantly. The NiMH fade, but
can be persuaded to come back for a few shots by resting (not always the
case with all cameras - the Sigma is technically a 5v camera, and well
suited to the 4 x 1.2v produced by NiMHs, though able to take the 6v
provided by the CRv3s).
The big thing is the cost. Two of the disposal lithium batteries cost
$35 in the UK (£9 each), while the same money will buy a complete set of
4 AA NiMHs and a charger, which will do several hundred 'runs' before
getting old. Two sets of NiMHs will match one loading of CRV3s in
capacity. I like my digital photography to be low-cost in consumables.
So no more CRV3s.
David
