When Is Power Cable Required on RADEON X800?
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
When is a separate power connector to the main power supply of
the PC required for an X800 video card? I purchased an X800 SE
and the seller is claiming that no external power connection is
required to use the card. ATI's own documentation is
ambiguous. It begs the question by giving directions like "If
your card requires an external power connection...." How can
you tell which type you have?
Will
Internet: westes at earthbroadcast.com
11 answers Last reply
More about when power cable required radeon x800
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    If the card has an external power connection it is needed. The reason the
    ATI instructions are vague is they cover a multitude of different cards. The
    seller is telling you wrong.
    "Will" <DELETE_westes@earthbroadcast.com> wrote in message
    news:taSdnQff9eL7a4XfRVn-2g@giganews.com...
    > Will
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    What functions will the external power connection provide?
    What would be the expected behavior of the card if the power is
    not plugged in? The seller is claiming he tested the card
    without supply an external power connection.
    Will
    "Dave" <a@a.com> wrote in message
    news:aU6Sd.43191$XY5.5202@fe2.columbus.rr.com...
    reason the
    of
    X800 SE
    is
    "If
    can
    > > Will
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    On Sun, 20 Feb 2005 12:43:17 -0800, "Will"
    I'm not aware of any x800 that does not have a full MOLEX connector.
    Are you saying that yours does not have a connector ?
    Or if it does - use it, and make sure nothing else [ other than the
    video card ] is connected to that cable.
    Which card do you have ?
    ¸ô¶ó
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    The function of the connector is to supply the power needed by the GPU. The
    mobo traces going into the AGP slot are not wide enough to carry the current
    needed by the modern processors. Much the same is the ATX 12 V connectors on
    modern MOBO near the CPU to provide power. IT WILL NOT WORK WITHOUT THE
    POWER CONNECTOR AND YOU MAY FRY YOUR MOBO TRYING. What is the big deal
    anyway, hook it up and be done with it already.
    news:isKdnVWIpIlHnYTfRVn-vg@giganews.com...
    > Will
    > reason the
    > of
    > X800 SE
    > is
    > "If
    > can
    >> > Will
  5. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Does this change with PCI Express?
    I can't hook it up because I don't have the cable yet.
    Will
    news:qN7Sd.43352$XY5.1455@fe2.columbus.rr.com...
    the GPU. The
    carry the current
    connectors on
    WITHOUT THE
    big deal
  6. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    PCI-e supplies more power, but still not enough for the most power hungry
    chips, most still have the external floppy connector on them. They have the
    cable you nedd at any store that sells computer equipment. even Wal mart has
    the splitter cables.
    news:ZJKdnSPWxPOLkYTfRVn-rg@giganews.com...
    > Will
    > the GPU. The
    > carry the current
    > connectors on
    > WITHOUT THE
    > big deal
  7. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    borolad@myowseintheboro.org wrote:
    > On Sun, 20 Feb 2005 21:42:26 -0000, "Ben Pope"
    >> X800XL. I think it's the only one though (although that'll probably
    >> bite me like it bit you :-p)
    > Can't see how it will handle the wattage, and yes it ' bit ' me. I
    > know ASUS don't follow the ATi spec on power supply.
    AFAIK it's on an 110nm process (albeit not SOI), so it should be quite good
    with power requirements.
    It's not just an Asus product,
    Sapphire have them:
    http://www.sapphiretech.com/vga/x800-xl.asp
    Powercolor:
    http://www.power-color.com/PCIE_X800_R43C-TVD3D.htm
    Gigabyte:
    http://www.giga-byte.com/VGA/Products/Products_GV-RX80L256V.htm
    err... probably others.
    Ben
    A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
    Questions by email will likely be ignored, please use the newsgroups.
    I'm not just a number. To many, I'm known as a String...
  8. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    In article <taSdnQff9eL7a4XfRVn-2g@giganews.com>, Will says...
    You need to use it when using 3D.
    Conor
    An imperfect plan executed violently is far superior to a perfect plan.
    -- George Patton
  9. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    If it's anything like the 9800 Pro, it just uses a standard 3.5" floppy
    drive connector; you don't need the big splitter/5.25" converter that ATI
    includes (but remember to NOT install the connector backwards - something
    that can be done if you try hard enough with the 3.5" type connector - or
    you'll fry the card!).
    - Daniel
  10. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    If you don't use the external power cable on a PCI-E RADEON X800,
    what is the result? With AGP I guess the card will sound an
    alarm condition at power on. With PCI-E I gather the board will
    power on okay and the motherboard will continue to work. But
    will the GPU run at a lower speed?
    Will
    news:PY7Sd.43358$XY5.11019@fe2.columbus.rr.com...
    power hungry
    They have the
    Wal mart has
    > > Will
    by
    > > the GPU. The
    > > carry the current
    V
    > > connectors on
    > > WITHOUT THE
    the
    > > big deal
  11. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    If there is a power connector on the card, it is there for a reason!
    Don Burnette
    "When you decide something is impossible to do, try to stay out of the
    way of the man that's doing it."
    >> hungry chips, most still have the external floppy connector on them.
    >> They have the cable you nedd at any store that sells computer
    >> equipment. even Wal mart has the splitter cables.
    >>> Will
    >>>> GPU. The mobo traces going into the AGP slot are not wide enough
    >>>> to carry the current needed by the modern processors. Much the
    >>>> same is the ATX 12 V connectors on modern MOBO near the CPU to
    >>>> provide power. IT WILL NOT WORK WITHOUT THE POWER CONNECTOR AND
    >>>> YOU MAY FRY YOUR MOBO TRYING. What is the big deal anyway, hook it
Radeon Connection Power ATI Graphics
