Tom's Hardware Forums » Graphic & Displays » ATI » Got a VIVO card and can't get MMC 9.06 to work? Solution h..
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Got a VIVO card and can't get MMC 9.06 to work? Solution h..
More Information
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Pre-patched file links at page bottom.
Manual guide:
1. Install MMC as you usually would do.
2. Find the file C:\Program Files\ATI Multimedia\main\DrvDShow.dll and
make a backup copy of it somewhere safe (incase you mess up).
3. Get a hex-editor and open C:\Program Files\ATI
Multimedia\main\DrvDShow.dll.
4. Find 81-7D-EC-00-E8-3F-03-74 and replace the value "74" with "EB" so
it looks like this: 81-7D-EC-00-E8-3F-03-EB.
5. Save the file, overwriting the original and you're done!
* NOTE for earlier versions of MMC: use the same procedure but search
for 81-7D-E8-00-E8-3F-03-74 instead, also here the value "74" should be
changed to "EB" so it looks like this: 81-7D-E8-00-E8-3F-03-EB.
* NOTE for upcoming versions of MMC: the string you wanna search for
might change but it's always the value of "74" that should be changed to
"EB", e.g. try to search for a part of it, like 00-E8-3F-03-74 (which in
both cases above is part of the hole sting), just make sure that there
should only be ONE instance of it in the file and you should be fine.
Version comparison:
81-7D-E8-00-E8-3F-03-74 -- from version 8.xx up to version 9.03
81-7D-EC-00-E8-3F-03-74 -- from version 9.06 up to version ?.xx (E8
changed to EC)
Get "pre-patched" DrvDShow.dll for MMC 9.03 and 9.06 here:
http://web.telia.com/~u19110420/
Related Pr oduct
Add a reply
Google Ads
