Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
On Tue, 15 Mar 2005 18:29:14 +0100, Tilman Hausherr <tilman@snafu.de>
wrote:
>On Mon, 14 Mar 2005 17:57:37 +0100, "Winfried Posur"
><emailmuell@posur.com> wrote:
>"Winfried Posur" <emailmuell@posur.com> wrote in
><d14fks$ptu$01$1@news.t-online.com>:
>>Yes it's an awful bug. It's not only that character size setting is ignored
>>and stuck to 96 dpi, applications which get the screen resolution from
>>Windows API (so some of mine) will not display correctly. You can use the
>>new driver only with 96 dpi set. I really wonder how such a bug is not seen
>>in beta testings. No one using 120 dpi ?
>I have the same problem. I'm using the large fonts. After installation,
>the Windows task bar is much much smaller. Changing the advanced screen
>settings or the appearance (instead of "normal", to "big fonts") doesn't
>help. I gave up (!), and deinstalled everything from ATI. Now I'm using
>the Windows XP default driver, which results in too many crashes while
>working, but at least the fonts are like before.
>Additionally, installation hangs when installing the WDM drivers. (No
>idea if I need them). I have Windows XP SP2 with all patches.
>I'm really angry. I liked ATI because of their unified drivers that were
>so easy to install. If this won't get corrected fast, I'll never buy an
>ATI product in my life again.
The font problem seems to be solved with 5.4. Note that they don't
mention it as "solved issues" in the release notes. So much for honesty
