Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
Thanks for the info. I'm going to play around with MultiDesk and see if I
can configure something useful with that while I'm waiting for ATI to reply.
I'm not holding my breath on this one. I'm willing to add a TV Wonder, I was
going to so I have a second tuner so I can record one thing while I watch
another. I asked them to tell me if that's the answe but I haven't heard
back yet. If that'll lets me run a MMC TV window on the secondary monitor
I'll do it. But if that won't work either, I'm getting rid of this card and
getting a Theatrix. I'll just put the 9600XT I had in this machine back
where it was and get another card for the other pc. $300 and it doesn't do
what they said it'll do? I don't think so...Bye Bye AIW
"Cqtip" <tkutchno@spamcomcast.net> wrote in message
news:FvOdnTVtBLkv4aLfRVn-jw@comcast.com...
> Pagan wrote:
>> "zzipper" <zzipper@sympatico.ca> wrote in message
>> news:c6N_d.28838$N8.840890@news20.bellglobal.com...
>>>I've removed CCC and installed the normal ATI control panel. In the
>> Overlay
>>>tab, there is no Theatre Mode options. Can you please tell me the exact
>>>driver and control panel versions you have installed? Thanks
>> I'm using the normal ATI control panel.
>> TV on the second monitor only works in clone mode, as far as I know, and
>> it
>> fills the screen on the second. It isn't too hard to change to and from
>> extended desktop, if you really need it. That's what I do, but for me,
>> there's few times where I actually need an extended desktop.
>> Pagan
>>>"Pagan" <DirtySanchez@chonch.com> wrote in message
>>>news:113km98nipiau90@corp.supernews.com...
>>>>news
Yq_d.24938$N8.670426@news20.bellglobal.com...
>>>>>Hoping for better help than I've had from ATI so far. Their response to
>>>>>my
>>>>>question is 'it doesn't work with the 9600'. My reply was it worked
>> with
>>>>>a
>>>>>9600XT and a TV Wonder so why not with an AIW9600XT? I suspect a
>> registry
>>>>>setting? Could something be limiting it's ability to reposition? Any
>>>>>help,
>>>>>suggestions welcome
>>>>>Thanks
>>>>>zz
>>>>Going to advanced properties, go to the Overlay tab, and on the bottom
>>>>you'll find Theater Mode Options. I fiddled with the settings in there
>>>>and
>>>>got TV output on the second monitor.
>>>>Pagan
> Not saying this is a solutions, but it may get you thinking.
> It sounds like in extended mode it's a no go for TV window drag and
> display on second monitor. Clone mode will display directX based video on
> one of the monitors but not both, based on which monitor is cloning which.
> When using control panel drivers and with the ATI system tray icon
> available I have setup two schemes to handle the problem of a quick and
> easy way to switch between having the "Video on PC" monitor and "Video on
> HDTV" monitor. Once setup all you do is right click the ATI in sys tray,
> select schemes and which one you want.
> NOTE: I'm just using clone mode, not using extended mode and I have AIW
> 9600 Pro (Cat 5.1 & MMC 9.03).
> You may be able to setup a compromise scheme in clone mode with video on
> second monitor and one in your normal extended mode when not watching TV.
> Additional info on possible problem with dragging to second monitor. I
> also have a TV Wonder on an older PC (Win98 who knows what drivers). When
> I used to drag the left edge of the TV window off screen normally the left
> side, it work as long as I didn't leave it there when I closed the
> program. If so the TV program wouldn't start without reinstalling the
> program (what a pain that was). I later found the only other way to
> correct the problem without uninstalling and reinstalling the program was
> to rename or delete the registry key value "PanelLeft" located in:
> "HKEY_LOCAL_MACHINE\Software\ATI Technologies\Multimedia\Features\TV\Panel
> 0"
> It seemed that the TV program couldn't start because of the error of where
> the upper left scan was supposed to begin which was off screen.
> That my input for whatever its worth.
