LimeWire 4.8.1 Problems
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I can't seem to get the LW interface up since I installed the 4.5
drivers just empty boxes. Anyone else having problems with the new
driver kit.
Thanks for any advice.
Take Care,
Griffin.
G
Guest
Guest
On Tue, 12 Apr 2005 22:09:37 -0700, Griffin McKorn <JPP@Zoso.org>
>driver kit.
>Take Care,
>Griffin.
Fixed my problem. Weird though, I rarely run an Admin account for
daily use only for maintenance and installs. When using the "Power
User" account I set up for myself the new LW has to be set in
compatibly mode (NT) in this case, before it will run, funky.
Thanks.
GM
G
Guest
Guest
Might be a Java problem... You tried the latest 1.4.2 or 1.5 JRE?
(Linewire IS Java based right?)
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
G
Guest
Guest
Digital Sheep wrote:
> And now all i get is a white screen where the progrqm info stuff
> should be ?. Enough is enough.
> Though i did just upgrade my videocard. So i can't blame it all on
> Limewire.
This doesn't happen to be the 6600GT you've been harping on about, does it?
Ben
G
Guest
Guest
> driver kit.
> Take Care,
> Griffin.
Disable forced FSAA in the ATI control panel.
G
Guest
Guest
It fixed itself somehow ?
On Wed, 13 Apr 2005 23:31:46 -0600, Kyle Peterson
>> driver kit.
>> Take Care,
>> Griffin.
G
Guest
Guest
Ben Go die like that other Pope.
>> driver kit.
>> Take Care,
>> Griffin.
G
Guest
Guest
How profound!
Take your acne medicine and run to mommy now.
