I' m having a problem when listening with headphones.
I get this irritating biep biep sound every 2 - 3 seconds or so. When listening to the speakers the bieps are not loud enough to be annoying.
I tried disabling the modem sound but that doesn't help.
Any suggestions are more than welcome.
I think you need to update you drives to new releases also while their update all. just search for what you need
do you know what sound you have ? here are updated drivers for your make and modle also here is the web link just click and go
<A HREF="http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp#PublicList" target="_new">http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp#PublicList</A>
4-19-2001 Sound Windows 95 Sound Driver for Yamaha DS-XG (v4.12.01.2020; 04-12-2001; 6.37M)
01-28-2001 Sound Windows 98 Sound Driver for Yamaha AC-XG (v5.12.01.2126.2-RC2; 01-05-2001; 5.11M)
01-28-2001 Sound Yamaha Soft Synthesizer for Windows NT (v3.01.20; 01-22-2001; 7.43M)
01-28-2001 Sound Windows 2000 Sound Driver for Yamaha AC-XG (v5.12.01.2126.3; 01-22-2001; 4.63M)
01-28-2001 Sound Windows NT Sound Driver for Yamaha AC-XG (v4.00.1019; 01-19-2001; 2.25M)
<P ID="edit"><FONT SIZE=-1><EM>Edited by ycs46241 on 12/04/01 07:38 PM.</EM></FONT></P>
Hi
Sorry for the time lag, the downloading of the drivers kept failing.
So I tried it...and it didn't help. Still stuck with the terrible beeps
While installing I did notice something remarkable:
when booting up, I do not here the beeps until after I log in. So I figured it was caused by one of the processes that are started after the login. I killed as many of them as I could, again with no success. ( of course I couldn't kill them all. Those windows complain about were apparantly system processes )
Maybe try XP ?
Here is another source for you to examine. Maybe you should get a BIOS update (this usually helps with Toshiba notebooks believe me, I work for those weirdo's).
If it only happens after he logs in then I doubt its a bios problem - more likely to be windows software. Incidently have you tried any other types of headphones. Long shot but you never know.
<font color=purple><b>Techie2001</font color=purple></b>
<i>(Crazy Alien)</i>
If it ain't broke, Don't fix it.
Yeah I know it's a long shot Techie2001. I work for Toshiba (I repair notebooks) and I know some models have lots of little problems. After contact with the factory it appeard most little problems with this model went away after a bios update. It doesn't mean it always works but hey, its much cheaper then sending it to me for repair, believe me ;-))
Peace all!
Success is basically nothing but overcoming the fear of faillure.
Mystery solved !
After a long long search on the internet I found out that some toshiba laptops have had sound problems ( they called it static )caused by polling of the infrared device.
I disabled the thing and guess what ? The beeping dissapeared completely !
Should have thought of that before, the IR port is right next to the audio out port.
So finally I can use my headphones !
