Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
Rick wrote:
> "Allan Anderson" <aganderson@remove-this.ukonline.co.uk> wrote in
> message news:428d118b$0$39093$ed2e19e4@ptn-nntp-reader04.plus.net...
>> "Rick" <nospam@earthlink.net> wrote in message
>> news:CmDie.2404$X92.1208@newsread2.news.pas.earthlink.net...
>>> This screensaver requires OpenGL 1.4.xxx or 1.5.xxx, and I have
>>> a Radeon 9700 Pro with Catalyst 4.12 WHQL installed. Sandra
>>> shows my OpenGL version as 1.5.4776, which should be fine,
>>> but when I try to run it I get an error saying my OpenGL version
>>> is too old.
>>> Could someone else try it and post back whether you get the same
>>> error? Flowerz is linked to from here:
>>> http://www.opengl.org/applications/windows/utilities/
>>> Thanks.
>> No go here on XP SP2 with Catalyst 5.3, which reports OpenGL Version
>> 6.14.10.4955. In Sandra, under Renderer Information, it shows
>> Version
>> 2.0.4955. I can't see anything else anywhere else. Where should I
>> see it?
> Sandra's version number is your OpenGL version (2.0).
> I heard from the author, and he says there's a bug in his
> screensaver that prevents it from running if it detects
> OpenGL 2.0 or higher. That would account for your
> not being able to run it, but it doesn't account for my
> problem.
> Thanks for the info.
Rick,
Have you had any other video card installed previously? I wondered if there
was some residue from another driver. Bit of a long shot. I appreciate the
reasons for running the WHQL driver, but it's a bit long in the tooth. I
know it *should* work with the opengl version it carries, but have you
considered upgrading to a newer driver (5.1 release for example?)
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0520-4, 20/05/2005
Tested on: 20/05/2005 17:29:57
avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
