Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
"Ian" <ian@nospam.net> wrote in message
news:428bbd7d_2@mk-nntp-1.news.uk.worldonline.com...
> Bratboy wrote:
>> "Rick" <nospam@earthlink.net> wrote in message
>> news:rsMie.4047$Ri4.3341@newsread1.news.pas.earthlink.net...
>>> "Rod Phipps" <oldmoose@bellsouth.net> wrote in message
>>> news:dbMie.2226$%R1.2118@bignews5.bellsouth.net...
>>>> Installed 5.5 catalyst last night and now WindowsMovieMaker is
>>>> acting up. Some files that previously opened fine, crash the
>>>> program now or load without previews.
>>>> ATI tech today said Catalyst installs new codecs. Gee, thanks for
>>>> the warning! Then he said I should figure out which ones got
>>>> replaced and find
>>>> them and install them.
>>> Thanks for the warning indeed. Thank God for guinea pigs.
>>> I would have asked the tech for a list of codecs Catalyst 5.5
>>> replaces, and then laughed disgustedly when he said they
>>> don't have that information.
>>>> Anyone know where a list of original install codecs for MovieMaker
>>>> 2 in XP
>>>> can be found?
>>>> The tech also said I could use a system restore point (which i made
>>>> before
>>>> installing the drivers) to go back to the previous driver, but it
>>>> didnt work. "No changes made to system".
>>>> Any help or ideas would be appreciated.
>> For the record, as far as Im aware there is only one codec ATI driver
>> installs. Its one for the WDM capture chips some cards use/have like
>> Rage theater chip (ATI WDM Specialized MVD Codec). Other than that,
>> at least in all the beta drivers Ive tested thus far no other codec
>> has ever been replaced. That said I am checking with someone else at
>> ATI to make sure Im right on this and will post back if learn Im
>> incorrect on this.
> Ahhhhh - the OP didn't say he had the WDM part installed. Maybe you are
> right!
Okay I picked some brains at ATI and this was the response I got over the
codec deal. Whether it will help you figure out whats wrong or not I dont
know but seems I was right that in general ATI drivers dont just replace
other codecs. Isnt much info but hopefully it can help you
----Reply I recieved----
....the WDMs and possibly MMC are the only likely sources of additional
codecs that I am aware of at the moment. And lets not forget the DVD decoder
download.
Of course if the problems are related to WMV files perhaps the Media Encoder
pre-requisite for MMC is involved. (Yes, I realize the problem is with movie
maker, but it is difficult to know all interdependancies is this day and
age.)
However, it is likley that something was removed prior to the driver install
and not replaced. Thus leading to a problem. Particularly if someone had
used MMC and subsequently used the ATI Software uninstall.
----End of reply---
