Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > wired / wireless network mixture or not ?
Forum Wireless Networking : Wireless General Discussions - wired / wireless network mixture or not ?
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Problem establishing a network between 3 units .
The set up :
-ADSL Wireless Modem Router connected ( wired ) to PC 1 via on board
LAN
-PC 1 has on board LAN ( SIS based ) - OS , XP home
-PC2 has wireless network PCI card - OS , XP Pro
-Laptop has wireless network PCMCIA - OS , 98se
( All wireless units are of Belkin 54Mbs / 802.11g )
Each unit succesfully can connect to internet and at the moment PC2
and Laptop shows they are in infrastructure mode .
However i can NOT establish a network and share folders between these
3 units . It appears to me that may be a bridge to be established
somewhere in this setup .
One idea comes to me that if i have another pci wireless card
attached to the same computer ( PC 1 ) as the modem router maybe a
full wireless network can be established. Is this the only solution
or even a correct one ?
Or maybe a bridge to be established on PC 1 , but i cant see any two
connections to bridge ..
What are your views .. Can i achive a succesful network with this
set up . ? Or does it need additional hardware ?
Thanks
Sponsored Links
the router should be all the 'bridge' you need. the first test is to get
the ip address of each machine and see if they can ping each other. if they
can then its likely a permissions issue or you don't have the right network
components installed. also check for firewalls on the individual machines,
they can prevent sharing also. the best thing is to use a firewall on the
router and then the internal machines shouldn't need one... makes things so
much easier.
"ReceT" <sata@gbnet.org > wrote in message
news:24uve0dana2rb36b12ban5vou8q4heu037@4ax.com...
> The set up :
> LAN
> Thanks
Reply to Dave
Hi
You need a Wireless Cable/DSL Router. One NIC in each Wired Computer, and
one Wireless Client in each Wireless computer. Nothing Else is Needed.
Once every thing is connected you have to configure the Network and the
sharing.
Log to this page it has a lot of links to instructions to Windows Network
Settings, and Sharing.
http://www.ezlan.net/Installing.html
http://www.ezlan.net/~network/router.jpg
Jack (MVP-Networking).
"Dave" <noone@nowhere.com> wrote in message
news:#gQUQGpZEHA.3228@TK2MSFTNGP12.phx.gbl...
they
network
machines,
so
> much easier.
> > The set up :
> > LAN
> > Thanks
Reply to Jack
Thanks .. As I understand , wired/wireless ,mixed network should be
straightforward as far as hardware is concerned. My 3 computers
each have different operating systems , xp home ( adsl modem router
wired to this ) the others XP pro and win98se have wireless hardware
The links you have given usefull understanding the principles but
each of the operating systems have their do,s and donts .. especially
as stated xp home network is sensitive to any firewall in the system
i am still fighting with it and / lots of reading now ..
My recommendation to average user is to stick to one operating system
in the network and maybe same make of wireless equipment to make the
things easier ...
thanks again ....
On Sun, 11 Jul 2004 17:23:55 -0400, "Jack" <JackMDS at veriz0n.net>
wrote:
>Hi
>sharing.
>they
>network
>machines,
>so
>> much easier.
>> > The set up :
>> > LAN
>> > Thanks
Reply to Anonymous
There are 1077 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
