ATI AIW9800 TV Sound Initialization
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi,
I just installed MMC 9.08 on a freshly-installed Windows XP system.
When I ran the TV setup, the TV Sound initialization did not appear. I
am not running in TV-On-Demand mode. I have NOT hooked up the line out
from the AIW card to the sound card, and yet, I still hear audio when
watching TV.
Can somebody explain why I don't see the TV Sound Initialization
wizard, and why I can hear sound even though I haven't hooked up the
sound card??
Any help is appreciated....
Brad
15 answers Last reply
More about aiw9800 sound initialization
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    "Brad" <bjmills@magma.ca> wrote in message
    news:1118843837.132786.85060@g49g2000cwa.googlegroups.com...
    > Hi,
    > watching TV.
    > sound card??
    I believe that card processes the TV signal and sends the audio directly to
    your sound card. I'd bet you still need to hook up your external
    connections to the sound card if/when you want to capture audio from an
    external source.
    As for the TV wizard, it's anybody's guess, but if things are working
    without it, so much the better. You don't really need it for the
    Soundblaster Audigy 2 cards anyway, but if memory serves, you can still find
    it under TV Setup.
    Pagan
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I appreciate the reply! In response to your first comment, perhaps
    this is so with the latest drivers, and not with earlier ones? I
    failed to mention that I previously had this card installed and I had
    to hook it up to the sound card as is described in the manual.
    Funny you should mention the Audigy 2, since I am using the Audigy 2 ZS
    Platinum Pro (what a mouthful) so perhaps that is why the Sound Wizard
    doesn't appear? I was unable to find anything on the ATI support site.
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I am also using an Audigy 2, and didn't notice the sound dialog didn't
    appear until you mentioned it. However, my sound still works, I just
    used the black multi-connector, the one that plugs into the "out" on
    the graphics card, and put the audio jack into the "line-in" on my
    soundcard. It may sound daft, but just check you've plugged the audio
    lead into the right hole.
    Steve :)
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    TS - that certainly explains things, like how I am getting sound
    without plugging the sound cable into the sound card! But why, why,
    WHY couldn't I find this info. on the ATI support site? Did you read
    this info on that site, or somewhere else, or what?
  5. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Sorry, where's the info on the ATI site?
  6. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    news:1118855215.193093.96990@o13g2000cwo.googlegroups.com...
    Around Cat 5.4(WDM drivers) and MMC9.06 the sound was changed to digital
    through the bus. No more analog sound(makes it compatible with MCE). Their
    is no sound setup wizard, its all wave now. Seems to have eliminated capture
    sound sync issues for me but I haven't tested it very much.
  7. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    news:1118860616.558987.243230@z14g2000cwz.googlegroups.com...
    Actually I figured it out. Sound my HDTV Wonder works the same way.
    Confirmation was made here, Rage3d.com or AVSforum.com(MCE compatibility)
    message boards. Current notes don't seem to mention it. Here's the info on
    ATI website but it looks like you just about have to know about it to find
    it.
    ID=10208
  8. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    news:1118876145.983656.62550@f14g2000cwb.googlegroups.com...
    Ok, try it this way:
    Customer Care
    left hand column click on Solve Problem
    Audio
    ATI Multimedia Center
    Should be the third subject on the first page.
    In the past searching for the ID number would take you to the page.
  9. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I agree Pagan. Thanks a lot TS! ATI should be in your debt...
  10. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
  11. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    "T Shadow" <knone@zilch.com.invalid> wrote in
    news:uh_re.44360$iu.41273@tornado.ohiordc.rr.com:
    >> ZS Platinum Pro (what a mouthful) so perhaps that is why the Sound
    >> Wizard doesn't appear? I was unable to find anything on the ATI
    >> support site.
    > digital through the bus. No more analog sound(makes it compatible with
    > MCE). Their is no sound setup wizard, its all wave now. Seems to have
    > eliminated capture sound sync issues for me but I haven't tested it
    > very much.
    I too have been having sound problems similar to what is described in
    this thread. Around the time I upgraded to MMC 9.6 and CAT 5.3 or 5.4
    my TV sound and picture stopped working (choppy picture and sound) and I
    noticed the lack of sound init dialogue. No clue or help in ATI support
    land.
    I've got the AUdigy 2 sound card and a 9600 AIW card.
    I finally downgraded to MMC 8.6 with the latest CAT drivers OK and that
    worked for a while but now I'm getting problems with the WDM drivers
    loading so I can't run MMC at all.
    Anybody got ideas on this WDM driver loading problem?
  12. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    "amica" <amica44@shaw.ca> wrote in message
    news:Xns9677C83F84913amica@64.59.144.76...
    > >> support site.
    > > very much.
    > land.
    OK here's the message in ATI's Knowledge base.
    External audio connection to soundcard LINE-IN not needed using WDM Capture
    Driver 6.14.10.6300 or higher
    The information in this article applies to the following configuration(s):
    ALL-IN-WONDER 9600 Series or higher
    WDM Capture Driver 6.14.10.6300 or higher
    Windows 2000 or Windows XP
    With the introduction of WDM Capture Driver 6.14.10.6300 on ati.com (as
    included in CATALYST 5.3), a new digital audio path is used for routing
    sound from the ALL-IN-WONDER to the soundcard, for ALL-IN-WONDER 9600 Series
    or higher.
    When running Multimedia Center's Initialization Wizard, you no longer need
    to set up the external audio cable configuration.
    You may detach the external audio cable that may be attached to your
    soundcard's LINE-IN or MIC input jack.
    It was a design change. I'd say it's unrelated to your original problem. You
    probably just got a bad install. Possibly it left a problem behind when you
    tried to go back. I'd run the CatUninstaller utility and try to reinstall.
    Look at the notes for the WDM drivers you may need to install them before
    the display drivers. Also make sure you have all the support files for the
    version you're trying to install.
  13. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Is there any way of forcing the new Catalyst drivers to let you use the
    line-in? I find I can adjust my sound needs better that way.
    Cheers,
    Steve :)
  14. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    On Fri, 17 Jun 2005 05:38:22 GMT, "T Shadow" <knone@zilch.com.invalid>
    >> >> support site.
    >> > very much.
    >> land.
    >or higher.
    Possibly a problem with files or devices from previous installs.
    Apart from running the ATI Software Uninstall Utility after
    uninstalling the old drivers, I'll usually remove the ATI devices
    shown in Sound, video and game controllers in Device Manager just
    before uninstalling the Display Driver itself, for a VIVO or AIW card.
    Just a thought, Patrick
    <patrickp@5acoustibop.co.uk> - take five to email me...
  15. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    newsgroups are the real support sites
Radeon TV ATI Sound Cards Graphics
