Yes No
Ads
Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > Flash card reader: write problem...
Forum Computer Peripherals : Digital Cameras Flash card reader: write problem...
Archived from groups: alt.comp.hardware,alt.comp.periphs.dcameras (More info?)
Hi everyones! Thanks to read.
I've bought an internal Flash card reader/floppy drive combo that you can
see here: http://www.directron.com/fa404.html I'm running it under
Windows98SE with the appropriate driver (Win2000/ME/XP doesn't need a
driver). I've cheated since i'll buy my digicam only in a week or two, but i
wanted to get done at setting up the card reader 1st. I've bought also an SD
256Mb card from Transcend. Tested the reader with a friend's Memory Stick
and could read his pictures without any problem. Later during the evening, i
did some tests with my 256Mb SD card. I tried to transfer files to it and
then discovered a problem. For a few files there's no problem, but when i
try to write hundreds of .jpg files (no i'm not exceding the capacity of the
card...!), i eventually end up by geting the message: "The directory or file
cannot be created" and the transfer stops. What have been transfered before
this error message appears is ok.
When i get this message, i can't add more files to the card. I've deleted
all the contents of the card, then retried. Got the same message. I thought
it was because of the file naming (because of french, i often use different
accented characters), so i copied the the files to a new folder, then with
ACDSee i did a batch rename for all the files, renaming them
000-001-002...and so on. When trying again to write those newly renamed
files, i get the same error. I'm able to write to the card a little more
files (about 300 out of 748, instead of the 153), but the write process
stops when the same amount of files have been transfered each time i try. I
don't have any clue. I've checked the support>FAQ section of Mitsumi's web
site, but could not find anything about this problem. Found instead the
deceiving message: "Important Notice for Mitsumi Product Owners:
Mitsumi does not offer repair services, repair parts, and does not have an
authorized repair shop." Well...nice! :-(
I'm searching on Google at the time i'm writing this, hoping that i'll find
something. Have any idea about my problem? Thanks for any useful replies.
Alain(alias:Kilowatt)
Montréal Québec
PS: 1000 excuses for errors or omissions,
i'm a "pure" french canadian! :-)
Come to visit me at: http://kilowatt.camarades.com
(If replying also by e-mail, remove
"no spam" from the adress.)
Reply to Kilowatt
"KILOWATT" <kilowatt"nospam"@softhome.net> wrote in message
news:KFpuc.78414$tb4.2844071@news20.bellglobal.com...
i
SD
i
the
file
before
There is a limit of how many files you can put into a single directory...
Can you put folders onto the memory stick? Can you put more files into those
folders?
Reply to Anonymous
- 0 +
How about formatting the memory card first?
Interesting - I ordered one of those combo drives 2 days ago.
Reply to Fish
"Noozer" <dont.spam@me.here> wrote in
news:s_puc.591957$Pk3.185256@pd7tw1no:
>> can see here: http://www.directron.com/fa404.html I'm running it
>> under Windows98SE with the appropriate driver (Win2000/ME/XP doesn't
>> need a driver). I've cheated since i'll buy my digicam only in a week
>> or two, but
> i
>> also an
> SD
>> Stick and could read his pictures without any problem. Later during
>> the evening,
> i
>> and then discovered a problem. For a few files there's no problem,
>> but when i try to write hundreds of .jpg files (no i'm not exceding
>> the capacity of
> the
>> or
> file
> before
> directory... Can you put folders onto the memory stick? Can you put
> more files into those folders?
There is a limit of 512 files in the Root directory of a FAT16 drive, but
no practical limit to the number of files in a directory (folder).
So to solve Kilowatt's problem, create a folder on the SD card and copy the
files into that.
Alternatively format the card as FAT32 which doesn't have the root
limitation - the disadvantage being that many digital cameras don't support
the FAT32 file system.
Reply to Anonymous
Thanks a lot for all your replies!
By searching on Google, i've found 2 interesting URLs: The following
describes a similar problem with someone's ZIP drive and the answer from
Iomega about his problem.
http://members.cox.net/nilshoke/Co [...] 200301.htm
(scroll down to the section with the phrase: "Frank Fiederlein ran into a
strange problem with his 100 MB Zip drive..." )
This one also explains pretty much (so you did! :-) ) the cause of my
problem.
http://home.merlin.mb.ca/~kolson/t [...] 71103.html
Thanks anyway for your replies, since they confirmed that my problem was
exactly related to file system limitations. Now by copying the content to a
folder instead of the root, all the files are transfered without this error
message. Nice of you to reply so quickly...i appreciate!
Montréal Québec
Reply to Kilowatt
Be sure to reformat the SD card in your camera before use! You may not get
any warning of impending doom for your photographs.
"RFJ" <rfjoyner@REMOVE.THIS.hotmail.com> wrote in message
news:Xns94F9DEFF08D8FRFJ4NJK@216.196.97.131...
> >> or two, but
> > i
> >> also an
> > SD
> >> the evening,
> > i
> >> the capacity of
> > the
> >> or
> > file
> > before
the
> files into that.
support
Reply to Anonymous
- 0 +
BACK TO THE BASICS, HUH?
Cool...it works. Thanks to the quikie from RF
> problem.
> Montréal Québec
Reply to Fish
Yes FiSH...you gonna' love this thing! ;-)
Reply to Kilowatt
- 0 +
Archived from groups: alt.comp.periphs.dcameras (More info?)
Hey KIlo, you're right - I DO love it. Came in the mail yesterday.
No more card adapters!
I installed the Media Formatting utility that came on the mini cd. The
program didn't work. Oh well, I wouldn't use it anyway. Uninstalled that
program.
This bugger is pretty slick. I've been using my cards for file transfers
a bunch, and this makes it that much easier.
Reply to Fish
Happy to see that you like the reader! No problem here with the version 2.05
under Win98SE. I bought it OEM so i had to go to the website for the driver.
They say the under Windows 2000 sp2 or XP, you don't have anything to
install...
Montréal Québec
Reply to Kilowatt
There are 2288 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Best 24" TN-panel monitor for gaming/Movies under $225?
By revolution2718, 4 days ago:
I have that same model and am a big fan. The colors need some tweaking out of of the box,...
Best offers
