G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
Hello All,
I work as a Network Manager for a Fortune 500 company and a bunch of my
XP clients got the following message:
"Due to an unidentified problem, Windows cannot display Windows
firewall settings"
Some of the symptoms associated with it:
* Cannot open firewall settings
* Cannot get inbound traffic to work (Outbound worked)
* Cannot run an IPCONFIG on the system with the problem
* Cannot look at TASK MANAGER -> NETWORK tab
Things Noted:
If you change the system date 3 months back and reboot, the firewall
settings worked!
Solution:
We use APC UPS systems on these XP workstations. If you have the APC
service loaded on your system, there is a flaw in which the JRE
certificate embedded on it expires on 7/27/2005 (see their support site
for the article). If I disabled the APC service and reboot, "whooptie
doo" the firewall settings come back and the systems continure to work.
APC recommends updating the software version of their product to the
latest and greatest (7.04 I think) but they do not acknowledge this
issue.
I hope this solution helps you guys as it helped me.
Sincerely,
KEY-K
Hello All,
firewall settings"
Things Noted:
settings worked!
Solution:
issue.
Sincerely,
KEY-K
