G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I bought a Saphire x800 XT about 6 months ago and was able to get it
installed and working correctly. I tried updating the catalyst drivers
today (4.9 to 5.6), but everything seemed to go wrong. Installation
was unsuccessful. I tried to unistall and blow away all of the old
drivers with Driver Cleaner and install to catalyst 5.6 drivers from
scratch with no luck. I tried going back to the drivers the card came
with, however, it will not install.
I have tried installing in safemode, I have also tried hitting F8
while booting up and activating "VGA Mode" without any success.
When I install from the disk, installation begins and starts loading,
then it says that it needs essential files that are on the driver
installation disk. I already have the disk in the disk drive, but it
fails to reconize the files on the cd.
Edit: I am running Windows XP SP1
If I download the drivers on the internet and try to install, I get
this message:
"Setup was unable to complete the installation. Try to setup your
display adapter with a standard VGA driver before starting setup."
I currently do not have a driver loaded, and I am unable to get a
driver loaded. If anyone knows any solutions, please let me know! I
will be happy with the original drivers (4.9) or the new ones (5.6). I
will keep an eye on this thread, If you need any more information, let
me know.
Thanks
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/ATI-X800-XT-problem-ftopict57741.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=291142
this message:
me know.
Thanks
