Tom's Hardware Forums » Graphic & Displays » ATI » Problems with AIW X800 XT AGP
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Problems with AIW X800 XT AGP
More Information
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I just bought an AIW X800 XT and it's having a few problems. The
worst problem is the TV display sputters along rather than move
smoothly. You can tell when you're watching a news ticker scroll buy on
the bottom of the screen. Also there is a delay of the signal on the
card. When I had my AIW Radeon, I could put on my TV and my computer and
it would have no delay on the computer's tuner. Now there's an echo.
Then there are the times when TV won't start. The scheduler won't start
and it says there's a "runtime error". The final problem is I can play
thing recorded with ATI VCR format from DVD disks. It worked fine with
my other AIW but it just won't work here, I get a runtime error. The
files play fine off the HD. Do any of you have any solutions? I have all
current drivers for the card and Remote Wonder II. I have all the
current Windows 2000 updates and latest Direct X.
My system is:
Windows 2000 SP4
CPU: 3.00 Ghz P4
Mem: 1GB DDR400 Dual-Channel
VC: ATI AIW X800 XT 256MB
SC: Creative SB Live 5.1
Thanks in advance.
John
Related Pr oduct
More Information
Is this the first AIW card you've owned? I had the 9800pro and the
software issues, especially when upgrading, was a real PITA. I was
considering going from the 800pro to this card for the video capture,
but after reading your post I'm reconsidering. Hope you find a solution.
More Information
The AIWs are, these days, poor choices for video capture. The Rage Theater
chip they use is previous-generation--the TV Wonder Elite uses a newer and
significantly improved chip, or you could go with one of the several boards
that have hardware compression and encoding (Hauppauge has a number of them
including at least one dual-channel), which should give capture quality
equivalent to the AIW with much less CPU workload. If you're talking TV
capture then an HD board might be a good bet.
--John
to email, dial "usenet" and validate
(was jclarke at eye bee em dot net)
More Information
Actually I've had a few ATI cards the first was a 3D Expression
then I upgraded to the firs AIW Radeon. That card still works today and
I just replaced it with this X800 XT. I never had any problem with jerky
video on the old AIW card. I did have problems with driver and software
upgrades. However when it worked it worked well. This X800 XT card works
great and is worth the money. I just think they need to iron out the
software problems.
John
More Information
I have no problems with the video capture. It's the live TV. It's
being processed so there's a delay and it's not playing smooth. When I
record the video it plays back smooth. Maybe there is a problem with the
buffers or something. It seems the ATI scheduling program is running ok
now. I still can't play .vcr files off a data DVD. I get this problem in
Windows XP and Windows 2000.
John
More Information
The 9800 has the delay also. But no idea what you mean playing smooth..
this may be the DVD problem. I just got a RCA VCR-DVD recorder. Nothing but
Nero and that was intermittently could play it's DVD creations. And it failed
to play it's 3rd creation. Swapped that for a Panasonic VCR-DVD recorder. so
far with all but ATI that works.
The ATI it seems can ONLY play commercial DVD's.
I'm on XP Pro with the aiw9800. Got this because of the GREAT AIW 128 I used
for 7 years on a P1. I'll seriously reconsider another AIW if I ever need one.
If the software and support sux. And the hardware only works IF it has good
software, not much sense in buying a Lamboghini if it's just going to sit under
a tarp in a closed garage.
Nice that Nero's DVD stuff does work.
more pix @ http://members.toast.net/cbminfo/index.html
More Information
>>> Theater chip they use is previous-generation--the TV Wonder Elite uses a
>>> newer and significantly improved chip, or you could go with one of the
>>> several boards that have hardware compression and encoding (Hauppauge
>>> has a number of them including at least one dual-channel), which should
> but Nero and that was intermittently could play it's DVD creations. And it
> failed to play it's 3rd creation. Swapped that for a Panasonic VCR-DVD
> recorder. so far with all but ATI that works.
> used for 7 years on a P1. I'll seriously reconsider another AIW if I ever
> need one. If the software and support sux. And the hardware only works IF
> it has good software, not much sense in buying a Lamboghini if it's just
> going to sit under a tarp in a closed garage.
The Nero DVD player seems to be relabelled Cyberlink. I hate to say this,
but the best results I've had performance-wise were with the nvidia player
(don't need any nvidia hardware in the machine to use it), but they charge
more for that than Nero or Cyberlink. It's also the only one I've
encountered that will smoothly and reliably decode HD broadcast streams.
There is a little bit of lag on my system between the video on the display
and the video on an adjacent TV--that's not really a problem unless you're
trying to run the video on the PC and the audio direct off-air or vice
versa. There was at one time a delay in the sound--that was a known bug
that was fixed somewhere along the way, although I haven't run the AIW in a
while (went to MCE and HD a while back) and it may be broken again.
The Rage Theater 200 was very nice compared to the BT8x8, but it's no real
improvement quality-wise over the current Phillips and Conexant chips that
have significant third-party support, and the lack of an HD tuner on the
AIWs is a serious shortcoming in my book--if you've not seen HD you won't
understand why it matters, if you have seen it on a high-res monitor then
you'll want it.
--John
More Information
"Husky" <cbminfo@toast.net> wrote in message
news:fu11c1lg7qdq1tudig0vsjnsd2jt82401a@4ax.com...
solution.
Theater
and
boards
them
TV
It's jerky like it's skipping a lot of frames.
but
failed
so
I haven't had problems playing any DVDs though.
used
one.
good
under
Yea these latest versions of ATI software is horrible. I finally got ATI
sheduler to stop quitting but apparently it doesn't record my shows now. On
top of it all, it now stops in the middle of recording for no reason. It
just freezes whatever's being recorded and doesn't budge until I press stop.
I wonder if there is some alternative software I can use for the TV tuner
and recording TV.
John
More Information
> solution.
> Theater
> and
> boards
> them
>> >> quality
> TV
> but
> failed
> so
> used
> one.
> good
> under
> ATI
> On top of it all, it now stops in the middle of recording for no reason.
> It just freezes whatever's being recorded and doesn't budge until I press
> stop. I wonder if there is some alternative software I can use for the TV
> tuner and recording TV.
The latest drivers are supposed to support Media Center Edition 2005, which
Microsoft did a pretty good job on. Of course you're paying for an XP
license to get it and if you need the full feature set of Pro then it won't
work for you (it's based on Pro but some things have been crippled--for
example it can join a domain at install time but not later).
> John
--John
More Information
"J. Clarke" <jclarke.usenet@snet.net.invalid> wrote in message
news:d9vauo12kh3@news1.newsguy.com...
capture,
> > solution.
> > Theater
newer
> > and
> > boards
of
> > them
> >> >> quality
talking
> > TV
It's
the
ok
in
> > but
> > failed
recorder.
> > so
> > used
need
> > one.
> > good
sit
> > under
> > ATI
press
TV
which
won't
Thanks. Actually I did manage to get the jerky TV smoothed out. I
uninstalled everything ATI and installed from the disk that came with the
card. It works better now. So it's definitely ATI's new TV software that's
the problem. I'll try Media Center 2005 and see what it does.
John
Add a reply
Google Ads
News
ATI's R430, X800 XL/X800 details revealed
Published on November 22, 2004
The X800 brand is about to get some more followers. Read more
ATI unwraps All-in-Wonder X800 XT
Published on September 10, 2004
ATI this week unveiled the Radeon X800-based All-in-Wonder X800 XT, its latest top-end multimedia card. Read more
ATI to launch X800 GT as new flagship graphics chip
Published on July 25, 2005
Before the arrival of its R520 and R580 flagship chips, ATI Technologies plans to introduce the Radeon X800 GT graphics processing unit (GPU) for the high-end market, according to sources at graphics card makers. Read more
ATI launches Radeon X800
Published on May 04, 2004
ATI has today launched the Radeon X800 VPU - supposedly the world's fastest visual processor. Read more
Latest Reviews & Articles
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
