ATI Radeon 9200 BIOS and XP Startup Problems w/ HP F50 LCD..
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hello,
I've got a brand new ATI Radeon 9250 card. (PCI card).
HP a1010n PC with onboard Video
HP F50 LCD Panel Monitor
I bought it for a special application to use the S-Video Output for TV.
(Already had an RF Modulator and RF TV distribution system on a boat.)
Before I installed the new ATI Radeon I went in the BIOS Setup and set the
Primary video to be the PCI slot for the new video to fire up. On turning on
the PC I immediately had a got weird blotchy distorted color screens on the
HP 50 monitor as if the card was at some resolution that the monitor
couldn't handle.
I took the card off site and put it in another older HP Celeron PC and
connected the VGA out to a Compac V700 CRT Monitor. I corrected the
resolution of the ATI card from 640 x 480 by re-enabling the onboard video
and setting it to 1024 x 768. (Plan on doing this back on the boat). Tested
the TV Output through a VCR and everything worked fine on the V700 crt
monitor and the TV Output.
Took it back to the boat and re-enabled the onboard video long enough to fix
the ATI resolution in Windows XP and set the ATI back as primary in both
BIOS and Windows. At this point rebooting worked fine and the HP 50 Monitor
worked fine. Note that I had not tried the TV OUT yet.
After enabling the TV OUT all seemed to work fine as long as we were up and
running in Windows XP. But reboot and the weird corrupted video from the ATI
to the HP F50 monitor was back again. But strangely it is only seeming to be
during the BIOS startup screens and the Windows XP startup screen. After
"Welcome" and the the "Desktop" the video is fine again. (Only that weird
firey melting distorted color video stuff at boot up is very discomforting
for the owner of the yacht. And I don't blame them.)
Has anyone seen this before? ATI Customer Support isn't much help. They
asked me to run a software utility and give them a debug text file ... which
they seemed to do absolutely NOTHING with. I told them a secret, that the
ATI card works fine on my V700 monitor, and it also works fine on another
(Magnavox? TV/Computer Display) special monitor that the customer brought
onboard. ATI has no answer, won't recommend a monitor, won't tell any
technical detail. They are just at the BLAME GAME. "Must be your monitor,
contact HP". "RMA is available if you want it". I ask for monitor
recommended specs or makes / models and I get no answer at all.
(Oh I also tried one time ... disabling the ATI again in BIOS and Windows
and leaving the TV OUT off. Reboot, set the ATI back enable and primary BIOS
and Windows, reboot again. And the card goes back to functioning normally
again even at reboot. So there must be something that goes wrong after TV
OUT has been enabled. Turning TV OUT off doesn't fix it. Only shutting the
card off completely (BIOS/Windows) and then back on again (BIOS and Windows)
gets it out of this trouble.)
Again when the problem exists... I can connect this other flat panel
Magnavox TV thing and the same BIOS and Windows startup screens come through
just fine. It seems to be some resolution/refresh thing that this HP F50
Monitor cannot handle. Also when the TV OUT has been on, but it is turned
off in Windows XP (the Radeon Display Settings Tab) the startup screens
still continue to the TV as well as the monitor (although corrupted to the
monitor screen). That's how I know for sure it is those startup screens
which are causing the corrupted video to the F50 monitor.
If anyone has any ideas I sure would appreciate it. This is the most trouble
I've ever had out of a video card. Please CC: via email if you respond.
Thanks,
Alan Spicer (a_spicer@bellsouth.net)
4 answers Last reply
More about radeon 9200 bios startup problems
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    if he has such a big boat, i wonder why a 9600 is such a pain in the butt.
    92xx are know to give lots of problems.
    "Alan Spicer" <a_spicer@bellsouth.net> wrote in message
    news:yoEze.40947$qm.26065@bignews5.bellsouth.net...
    > Hello,
    > on the PC I immediately had a got weird blotchy distorted color screens on
    > the HP 50 monitor as if the card was at some resolution that the monitor
    > couldn't handle.
    > Tested the TV Output through a VCR and everything worked fine on the V700
    > crt monitor and the TV Output.
    > fix the ATI resolution in Windows XP and set the ATI back as primary in
    > both BIOS and Windows. At this point rebooting worked fine and the HP 50
    > Monitor worked fine. Note that I had not tried the TV OUT yet.
    > and running in Windows XP. But reboot and the weird corrupted video from
    > the ATI to the HP F50 monitor was back again. But strangely it is only
    > seeming to be during the BIOS startup screens and the Windows XP startup
    > screen. After "Welcome" and the the "Desktop" the video is fine again.
    > (Only that weird firey melting distorted color video stuff at boot up is
    > very discomforting for the owner of the yacht. And I don't blame them.)
    > which they seemed to do absolutely NOTHING with. I told them a secret,
    > that the ATI card works fine on my V700 monitor, and it also works fine on
    > another (Magnavox? TV/Computer Display) special monitor that the customer
    > brought onboard. ATI has no answer, won't recommend a monitor, won't tell
    > any technical detail. They are just at the BLAME GAME. "Must be your
    > monitor, contact HP". "RMA is available if you want it". I ask for monitor
    > BIOS and Windows, reboot again. And the card goes back to functioning
    > normally again even at reboot. So there must be something that goes wrong
    > after TV OUT has been enabled. Turning TV OUT off doesn't fix it. Only
    > shutting the card off completely (BIOS/Windows) and then back on again
    > (BIOS and Windows) gets it out of this trouble.)
    > through just fine. It seems to be some resolution/refresh thing that this
    > HP F50 Monitor cannot handle. Also when the TV OUT has been on, but it is
    > turned off in Windows XP (the Radeon Display Settings Tab) the startup
    > screens still continue to the TV as well as the monitor (although
    > corrupted to the monitor screen). That's how I know for sure it is those
    > startup screens which are causing the corrupted video to the F50 monitor.
    > trouble I've ever had out of a video card. Please CC: via email if you
    > respond.
    > Thanks,
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    * Who said anyone had a big boat? What if they had it in a big house? Noone
    either said anything about 9600 being a pain. Do you suggest that a 9600
    won't have this problem? Anyway I bought the card for main sole purpose of
    providing TV OUTPUT. I didn't think we needed the best Gamers Card to get a
    single simple S-Video output. Even this one seems to me as overkill. This
    isn't an application for Super Video Game System. Just simply to repeat the
    video out so it can be viewed elsewhere. Anyway IMHO this problem that's
    happening shouldn't be happening.
    This is in the Fort Lauderdale, Florida area. Lot's of boats here. big and
    small. This one is like 76 foot. Big is over 100 feet, especially getting
    into 200 footers. Should I buy a bigger card to fit in a big boat? ;-)
    "x.C" <email> wrote in message news:gNSdnQEklpGMiVLfRVn-hQ@rogers.com...
    >> Hello,
    >> the Primary video to be the PCI slot for the new video to fire up. On
    >> turning on the PC I immediately had a got weird blotchy distorted color
    >> screens on the HP 50 monitor as if the card was at some resolution that
    >> the monitor couldn't handle.
    >> video and setting it to 1024 x 768. (Plan on doing this back on the
    >> boat). Tested the TV Output through a VCR and everything worked fine on
    >> the V700 crt monitor and the TV Output.
    >> on another (Magnavox? TV/Computer Display) special monitor that the
    >> customer brought onboard. ATI has no answer, won't recommend a monitor,
    >> won't tell any technical detail. They are just at the BLAME GAME. "Must
    >> be your monitor, contact HP". "RMA is available if you want it". I ask
    >> for monitor recommended specs or makes / models and I get no answer at
    >> all.
    >> respond.
    >> Thanks,
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Alan Spicer wrote:
    > Hello,
    > couldn't handle.
    > Thanks,
    I've read through that a few times and I don't understand. Firstly, the
    driver should allow you to set and store independent configurations for
    display 1, the monitor, and display 2, the TV. You should not have to
    watch the monitor at TV settings, therefore, and similarly, the TV
    should come up with its correct settings even if the monitor is also
    connected to the VGA out. How are you connecting the TV, are you using
    the Composite or S-Video out sockets? You are not trying to use one of
    the VGA/DVI connectors with an adaptor are you?
    Let's break this down step-by-step.
    avast! Antivirus: Outbound message clean.
    Virus Database (VPS): 0527-2, 08/07/2005
    Tested on: 09/07/2005 20:19:29
    avast! - copyright (c) 1988-2005 ALWIL Software.
    http://www.avast.com
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    * I don't normally bottom post but I'm gonna reply within your message as
    quoted. Thanks for the reply:
    "Ian" <ian@nospam.net> wrote in message
    news:42d02359_4@mk-nntp-2.news.uk.tiscali.com...
    * It gave me 3 actually in Display Settings. I have at times deleted 1 of
    them
    1.) Plug-n-Play Monitor on ATI Radeon 9250
    2.) Plug-n-Play Monitor on Intel Graphics (onboard video this is disabled)
    3.) Plug-n-Play Monitor on ATI Radeon 9250 (last I left this is deleted)
    I've deleted the 3rd, or sometimes disabled it. I disable the 2nd (onboard
    video)
    When the TV Out is enabled from the Advanced, ATI "displays" tab and it is
    OK'd and closed #1 changes:
    1.) (Multiple-Monitors) on ATI Radeon 9250
    The Advanced, ATI "displays" tab seems to be the place to enable TV OUT
    monitor or not. There is no other TV Monitor which appears. * Unless this is
    my mistake right here. The 3 are all supposed to exist. I am supposed to
    configure the TV OUT on the #3 one, but not on the #1 one?
    But I don't think that is possible. Out of three ONE has to be the Primary
    Display which holds the Windows Desktop normally. If you enable other ones
    they can only be "Extended Desktops" and you cannot see the main things in
    Windows from them. I cannot seem to have two Primary Display out of the 3.
    (assume #2 onboard is disabled).
    >You should not have to watch the monitor at TV settings, therefore, and
    >similarly, the TV should come up with its correct settings even if the
    >monitor is also connected to the VGA out.
    * I would tend to agree. But all I come up with is 1 Primary Display which
    has in the Advanced, (ATI tabs) Displays ... the capability of turning on TV
    output.
    >How are you connecting the TV, are you using the Composite or S-Video out
    >sockets?
    * I've tested both. Off site I ran it here with Composite Video Out through
    a VCR to a TV. The only problem I saw was the "Video Overlay" you have to
    turn off Video Overlay to the Monitor in order to view MOVIES on the TV
    screen. I don't remember exactly where that was but I know I had to keep
    toggling it to change the video of movies between the monitor or the TV
    screen. (I assume that's a different issue, but I haven't explored it in
    depth. I assume if I installed on a different computer here, and then went
    back to the site [a yacht in a marina] that the drivers install there would
    reset all of the settings. Anyway I'm pretty sure I left the overlay back on
    the monitor after testing off site.)
    On the actual site we are using the S-Video Output for TV. Because we
    already had an RF Modulator that takes S-Video inputs only.
    > You are not trying to use one of the VGA/DVI connectors with an adaptor
    > are you?
    * Not using any adaptors at all. The video jack on back of ATI Radeon 9250
    PCI is a Standard VGA monitor jack. The other end is the same, standard VGA
    monitor jack. No DVI is in use. We are using normal Analog.
    * I hope I've laid it out pretty good. Maybe you are on to something here,
    or helping me be on to something. Why is the installation creating 2 ATI in
    the Display properties in addition to the Onboard Intel Video? Is one of
    them supposed to be configured independantly as the TV OUTPUT and the other
    as the MONITOR output? If so, how do you get them both to be a Primary
    Display in Windows XP? It doesn't seem possible.
    I'm gonna read again the manual for the ATI 9250 and see if I see anything
    there. Thanks for the reply and thoughts and questions.
Radeon Hewlett Packard ATI Graphics
