Tom's Hardware > Forum > Graphic & Displays > ATI > serious memory leak - radeon 9600 pro AIW
Forum Graphic & Displays : ATI - serious memory leak - radeon 9600 pro AIW
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
My PC is an ASUS A7V266 with 1GHz Athlon. The ATI multimedia S/W that came
with my Radeon 9600 AIW seldom works for very long without hangs or crashes.
Here is an interesting problem I discovered which might indicate some
underlying general problem. If I run Windows System Monitor while recording
a TV progam, SysMon shows UNUSED PHYSICAL MEMORY goes down to almost nothing
in about 10 minutes. I tested this with two 256 Meg SDRAMS (512 total), and
then with only a single 256 Meg SDRAM installed. This memory leak happens
every time I record from TV or VCR etc.
Has anybody here heard of a problem like this. How to fix it?
TIA. Bill S.
Sponsored Links
> TIA. Bill S.
I record movies daily and watch nightly. Also run app which shows CPU
use and mem load. CPU use never goes above 50% and mem use shows no
appreciable increase during recording or viewing even if I am doing
other things at same time. If your problem only occurs while running
win sys monitor, I would suspect that app rather than ATI.
My sys uses is Intel MB and P4 CPU, ATI AIW 9600XT but that should make
no diff. BTW, software I use is the CD which came with the 9600, NO
updates or upgrades; every time I updated or upgraded software, the
system went bad and/or crashed.
Hope you solve your problem.
Jack.
Reply to Jack
There are 793 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
