Tom's Hardware > Forum > Graphic & Displays > ATI > TV Mirroring Problem, ATI Radeon Mac Edition
Forum Graphic & Displays : ATI - TV Mirroring Problem, ATI Radeon Mac Edition
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I have an ATI Radeon Mac Edition video card with s-video output. I am
having a very odd problem with the output of this card. I've worked
with ATI extensively and they have concluded that it must be a hardware
failure but since the card is no longer under warranty they won't test
it for me. I suspect that the card is fine. Here is a description of
the problem. I tried writing all this out in words and it was huge and
confusing, so I've used a key to simplify the descriptions of the test
setups.
TV A is a TV without s-video input
TV B is a TV with s-video input
TV C is a different TV without s-video input
VCR A is a VCR without s-video input/output
VCR B is a different VCR without s-video input/output
Card is the computer's video card
DVD is a DVD player with s-video output
SV is an s-video cable
CX is a coaxial cable
RF is an RF modulator
These are the connections I have tried and the results:
Card - SV - TV B = perfect picture
Card - SV - RF - CX - TV B = good picture
Card - SV - RF - CX - (TV A or TV C) = distorted colors
DVD - SV - RF - CX - TV A = good picture
Card - SV - RF - CX - VCR A Record, then VCR A - CX - TV A = distorted
colors, also Tape from VCR A in VCR B - CX - TV B = distorted colors
DVD - SV - RF - CX - VCR A Record, then VCR A - CX - TV A = good
picture, and tape from VCR A in VCR B - VX - TV B = decent picture
After all this troubleshooting it appears to me that all components are
functional. My only idea at this point is that the output of the card
deviates from the s-video standard. Somehow this is being propagated
through the RF converter to the TVs, but TV B has circuitry that
corrects the image. ATI tech support has stated that the card meets
whatever s-video standards are out there. My computer does have all
the latest drivers, etc. The VGA output from the card works fine.
All I want to do is connect the card to TV A (I don't own TV B or I'd
just use that). Any suggestions will be appreciated.
Kris
(the email address I'm posting this from is dead, so please respond to
the group, or to the address below)
b i n a r y _ d r e a m s
a t
s o f t h o m e
n e t
Sponsored Links
Excellent idea! I never even considered grounding.
My house was built in the 60's and the majority of the receptacles
(power outlets) do not have ground conductors. I've replaced them with
3-prong GFCI receptacles as permitted by the electrical code. However,
this does mean that my computer is not actually connected to a ground
conductor.
The RF modulator and VCRs don't require ground connections.
I will try connecting the computer to a grounded receptacle tonight.
If this doesn't work I will try to borrow that DVD player again and use
it in place of the RF modulator to determine if that is the problem.
Thank you for your help. I will post the results of these further
tests.
Reply to Anonymous
<kris7@softhome.net> wrote in message
news:1122485437.743290.123660@f14g2000cwb.googlegroups.com...
> conductor.
> tests.
I worked on house a couple of years ago that had a string of outlets that
had hot and neutral wires reversed at the outlets(10). The outlets had
ground wires that would have tripped the circuit breaker but between the
string and the entrance panel was about 10ft of 2 conductor wire. Naturally
this was in remodeled basement. IOW don't assume anything and verify
everything. FYI, GFCI does not work as well w/o being grounded.
I recommend grounding the outlet(s) (to a real ground)anyway but it may not
be that simple. This is comprehensive info.
http://www.epanorama.net/documents/groundloop/
Reply to Anonymous
I haven't actually unplugged everything once it was all connected, but
I have rebooted the computer and cycled power to the RF modulator and
everything else at the same time. Would you expect a different result
from actually unplugging everything?
Reply to Anonymous
Connecting the computer to a grounded receptacle didn't change the
problem. However, the grounding from the panelboard in this house to
the electrical service outside doesn't meet the current electrical
code. I may try connecting the computer to the service panel outside
(which I know is solidly grounded to the water pipes, two ground rods
and the gas piping) to see if that changes anything.
I probably won't be able to get that DVD player until next week.
Reply to Anonymous
Actually, GFCI doesn't require a ground conductor at all. A GFCI
device only compares the current on the phase conductor to the current
on the neutral conductor. If they vary by more than 5mA then it
disconnects the phase conductor (20mA for large GFCI devices, such as
>1200A circuit breakers). A GFCI circuit breaker usually doesn't have a ground connection other than the neutral.
You're right about not assuming anything though. I will connect to a
maintenance receptacle directly off the service panel for the next
test. I'll also verify that the receptacle is wired correctly.
This power stuff is right up my alley. It's the signal processing and
TV/video standards that I'm clueless about.
Reply to Anonymous
Maybe, depending on the audio/video equipment. New stuff yes. Either way it's easy enough and should have been unplugged
anyway.
I have my pc and home audio/video stuff all wired with each other all over the house and have to unplug the 110 after
making changes so the input/outputs are re-tested or strange things happen. The audio/video receiver (pioneer vsx-d608)
has over 50 input/output jacks on the back and they will only work after the tests it does when the 110 plugged in.
One other thing that might be useful (was for me) is that some components in/output can also be used for converting and
splitting. For example my vcr in (all) signal goes out (coax & s-video) to a back room tv and the audio/video receiver.
Hope that helps
Dan
--end
Reply to Anonymous
news:1122564139.522157.199470@f14g2000cwb.googlegroups.com...
Correct, that's a "feature" of the AFCI. Now I know I need to see if mine
are part of a recall.
Reply to Anonymous
I finally got a chance to borrow the DVD player again, but
unfortunately I realized why I hadn't tested it in place of the RF
modulator the first time. The DVD player doesn't have s-video input.
I was able to run another test though. I have a device called "Jam"
that lets me play console games on a computer monitor. It has s-video
input. So, I tried connecting the video card through the s-video cable
to the Jam and then plugging a monitor into to the Jam. The image came
through with the same color distortion as it does with the RF converter
and the TVs. This doesn't necessarily indicate that the RF converter
isn't the problem, but considering that it worked fine with the TV that
has s-video input I think it's not unreasonable to believe the problem
is elsewhere.
I'm pretty much out of ideas. Anybody have any other suggestions?
Thanks for all your help so far.
Reply to Anonymous
>is elsewhere.
The s-video type sockets on ATI VIVO and AIW videocards don't normally
have standard pinouts. You need to get an ATI lead that plugs into
the card and provides input/output options - usually s-video and
composite video, and sound connectors for an AIW.
Patrick
<patrickp@5acoustibop.co.uk> - take five to email me...
Reply to Anonymous
ATI tech support told me that I should use a normal s-video cable with
this card. Prior to that I had been trying to use a cable that was
supposedly made for ATI cards. It had s-video, composite and
mini-stereo connections.
Do you know where I could find an accurate pinout for this card? If my
cables are the problem then I would love to just make a custom cable
and be done with this issue.
Reply to Anonymous
Not sure what the actual pin-outs are; perhaps someone else here does.
I also don't know whether your card being a Mac edition makes any
difference. However, AFAIK there are several different types of leads
that ATI do: leads made for VIVO cards and those made for AIW cards.
Apart from the fact that AIW leads have audio connectors, I'm pretty
sure that neither will work with the opposite type of card. I'm not
sure what you use to output from a non-capture card.
It also makes a difference whether you're running the signal into or
out of the card: very often this is indicated by arrows moulded into
the plugs, and some leads are made for bi-directional comnnections.
The ATI lead you were trying to use sounds like an AIW one (it has
audio connectors). If your card is not an AIW, this may well be the
wrong lead.
You can buy the appropriate leads here:
http://www.svideo.com/ati.html; apparently they ship world wide.
HTH Patrick
Reply to Anonymous
> wrong lead.
> HTH Patrick
It should be easy enough to check that you have the correct input/output dongles, splitters or whatever you want to call
them. Ati's web site still shows all that information for even my old AIW 7500.
There are also the advanced display settings for stuff like sharpness, flicker, dot crawl, format. Might want to recheck
those.
Reply to Anonymous
On Wed, 10 Aug 2005 05:44:45 GMT, Danny Greaves <dandog@pacbell.net>
>> wrong lead.
>> HTH Patrick
Unfortunately, your newsreader has posted your comment under your sig
line, Danny, so it doesn't show in my reply: I'll quote it:
"It should be easy enough to check that you have the correct
AIW 7500.
"There are also the advanced display settings for stuff like
those."
Unfortunately, I can only see that the OP has stated that his card is
a Mac Edition Radeon - no more. He'll have to look that up himself.
Patrick
Reply to Anonymous
There are 510 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
