Tom's Hardware > Forum > Graphic & Displays > ATI > Gigabyte 9800 Pro Resistor Problem! HELP!
Forum Graphic & Displays : ATI - Gigabyte 9800 Pro Resistor Problem! HELP!
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi All,
I've managed to knock off 2 resistors whilst cleaning out my pc,The
problems is i can't find the little buggers,The 2 i need to replace is
R101 & C103 (Thanks gigabyte for printing this),they are located on the
left hand side about half way close to the edge of the pcb when looking
at the back (non gpu side) with the pci bracket on the right and the
agp slot at the bottom.
I've been told the graphics card is a R350 core (if this sounds
right?)and a xt revision board (don't quote me on this!),The part
number on the board is: 109-A07500-00,i got this from the top left when
looking at the gpu side with pci bracket on left and agp slot at
bottom,Printed in white.
Can anyone help me?
The boards NOT been powered up since loosing them (i'm dumb but not
that dumb!),so i'm hoping if i can get the correct resistor values then
off to maplins i shall go and the job should be a good'un!
Very Grateful for any help
I have a pic if anyones intrested email me! it wouldn't upload coz it
was too big! :(
peteec
Sponsored Links
There are 1355 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
