Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi there
I just got an ATI 9800Pro. I used to use the 5.6 drivers and had
no problem with graphic. I am now in the section when you use the
boat and most time, the water is white, like if it is ice. I see
no special effect to the water. Th rest of the graphic is normal
and very nice. It is only the water. Now this does not happen all
the time but more than 60% of all the "chapters" I am playing
that involves me driving this little boat, the water is white. I
can barely make out waves and such details in the water. When it
*does* work as it should (the other 40% of the time), the water
is fine. I upgrade to the 5.7 driver, to no avail. Can anyone
help? I am running at 11xx By 8xx, no special effect, details set
to medium, no Antialiasing... PLain vanilla settings
Specs
Athlon 64, 3000+
512 PC3100 ram
80 gig HD
DirectX version: 9.0c
Thanks
Hi there
Specs
Athlon 64, 3000+
512 PC3100 ram
80 gig HD
Thanks
