AIW 9700 Causes Power Down
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I have a DFI Lanparty 250g for Athlon 64 (Socket 754) in an Antec Sonata
case w/ 360W supply, and it runs very well as I originally built it to be an
HD multimedia machine (XP Pro). Using an Abit vguru Radeon 9550 jumpered to
be a 9600 (almost pro clocking), running a 3000+ Newcastle(?) clocked to
2.4GHz, 1 stick of 512M of Geil UltraX 4400 DDR at 253MHz, and an ATi HDTV
Wonder PCI card. It records whatever I get unscrambled over the air without
too much trouble, but it *could* be better.... Plays WMV-HD disks/files
quite nicely, even at 1080p. HD avi files are kinda choppy driving a Toshiba
dlp tv, though.
So, I was wondering if it would help to step up the video horsepower. The
only card I have handy with any higher horses is an AIW 9700 Pro. I can't
test it, though, because I can't even turn on the computer with that card
plugged in!!! CPU fan spins for a second, and then stops.
Two questions -
1. Why won't this card let me boot? It works just fine in two other pcs
where I've placed it, and I *did* connect the power adapter... <g> Might it
be the HDTV Wonder doesn't like the competition??
2. If/when I get a better card working in this system, how much is enough to
play files like the avi hd that stuttered its way accross the Toshiba's
screen?
Appreciate all guidance y'all might be able to give. Thanks!!
StewRat `8^Þ
6 answers Last reply
More about 9700 power down
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    "StewRat" <Giant_Rat@Sumatra.com> wrote in message
    news:3peig1ph7h8pnd8opcm4m1tm4e2ujjpj6r@4ax.com...
    > it
    Well, the easiest way is to take out the HDTV Wonder and see if it'll boot.
    > to
    > screen?
    Try enabling AGP Fast Writes with your Radeon 9550, if you haven't done so
    already. For some odd reason this activates DXVA with the ATi drivers, in
    all media player programs. It made a huge difference in playing 1080p
    content for my 9800Pro.
    "War is the continuation of politics by other means.
    It can therefore be said that politics is war without
    bloodshed while war is politics with bloodshed."
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Hey FoO,
    That's a good point. I'll have to write that down because my cheapie
    refurb 9800 Pro AIW arrives today!
    DaveL
    "First of One" <daxinfx@yahoo.com> wrote in message
    news:xsudnZ2dnZ2cvcD5nZ2dnfDKlN6dnZ2dRVn-z52dnZ0@rogers.com...
    >> it
    > boot.
    >> to
    >> screen?
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    One word of caution: enabling DXVA will turn the colors psychadelic,
    depending on which renderer is used. In Windows Media Player and Media
    Player Classic, there is a choice of renderers (default, overlay, VMR9...).
    If you see the crazy neon greens, try the different renderers; at least one
    will work normally.
    Also, depending on the renderer used, FSAA may multiply the workload, esp.
    with ripped subtitles. At the same time, SmartShader effects (porthole,
    sepia, etc.) can be activated. :-)
    "DaveL" <dave1027@comcast.net> wrote in message
    news:avydnRvyiI72lZfeRVn-qw@comcast.com...
    > Hey FoO,
    > DaveL
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    StewRat: Fast Writes serve no purpose whatsoever for ATI
    hardware and drivers, and will usually cause system instability
    when enabled. FW create a PCI buffer for video that can talk
    directly to a CPU, but this isn't necessary (or even desirable)
    for drivers that properly implement an AGP command set
    (such as ATI's).
    DXVA coming active on your system was coincidental to
    something else, not enabling Fast Writes.. e.g. installation of
    the MS patch required for it. Here's the complete procedure:
    Knowledge Base
    ATI Customer Care > How to Use > System Settings and Configuration >
    How to enable DirectX Video Acceleration (DXVA) in Windows Media
    Player 10
    The following steps will help you enable DirectX Video Acceleration
    (DXVA) within Windows Media Player 10
    1. Install Catalyst 5.6 or higher. Drivers before Catalyst 5.5 do not support
    DXVA acceleration
    1a. Reboot
    2. Install Windows DRM update, from:
    http://www.microsoft.com/downloads/details.aspx?FamilyId=73C2650F-BE61-4BD6-8408-1FD6E7827CD8
    2a. Reboot
    Note: Please refer to this article for more information:
    Update for Windows Media Digital Rights Management-enabled players
    http://support.microsoft.com/kb/891122/
    3. Install the following Windows Media Player Hotfix
    a. http://download.microsoft.com/download/f/9/6/f969ae58-75d4-4241-b58c-9a295372d8c0/windowsmedia10-kb888656-x86-global-enu.exe
    Note: Please refer to this article for more information on the Hotfix:
    Update to enable DirectX Video Acceleration (DXVA) of Windows Media Video
    content in Windows Media Player 10
    http://support.microsoft.com/default.aspx?scid=kb;en-us;888656
    4. Go into Catalyst Control Center. Switch to Advanced view
    5. Go to the Video, All Settings
    6. Scroll to the bottom of the Catalyst Control Page to find the
    Windows Media Setting option and ensure Windows Media Video
    Acceleration is checked on.
    7. Start Windows Media Player 10, go into Tools, Options (if the
    menu bar is not available, double the click title bar to display)
    8. Open the Performance tab and click Advanced under Video
    Acceleration
    9. Ensure Use high quality mode is selected. Click OK, OK.
    "DaveL" <dave1027@comcast.net> wrote in message news:avydnRvyiI72lZfeRVn-qw@comcast.com...
    > Hey FoO,
    > DaveL
    > >> it
    > > boot.
    > >> to
    > >> screen?
  5. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    As someone else already suggested, easiest would be to remove the HDTV
    Wonder (including its drivers, and do this before installing the
    9700AIW) and see if the combination is guilty for the problem. Another
    issue is the PSU - maybe it is not up to what it is required? It
    _should_ be adequate but maybe the specimen is of the weaker side of the
    pack. OTOH, if you remove the HDTV Wonder and the system starts working
    OK it might mean that a) the combination would not work or b) one
    component removed leaves the others enough juice to operate.
    > screen?
    The stuttering might be result of some piece of software requiring too
    much attention from the CPU as well as some general confusion of the
    system. Do you have any indexing services or anything like that usually
    running in the background? Sometimes they think you are not doing
    anything if you don't fiddle with your keyboard or mouse and start doing
    in the foreground whatever evil tasks they usually do in the background.
    This might result stuttering playback.
    gt
  6. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    On Mon, 22 Aug 2005 03:06:04 GMT, StewRat <Giant_Rat@Sumatra.com>
    >dlp tv, though.
    >Two questions -
    Sometimes makes a difference to ensure that nothing else is on the
    power adapter lead from the PSU, StewRat.
    >screen?
    Patrick
    <patrickp@5acoustibop.co.uk> - take five to email me...
Radeon Graphics
