Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Since installing the Cat 5.8's, my Media Library doesn't work.
It worked the last time I tried it.
Still using the Multimedia-center version 9.03.
Any ideas ?
Guess I should try the latest MMC version.....hmmmm
Running on a P4 2.8 with 9800 AIW.
Thx.
Jez, MBA.,
Country Dancing and Advanced Astrology, UBS.
'Realism is seductive because once you have accepted the reasonable
notion that you should base your actions on reality, you are too often
led to accept, without much questioning, someone else's version of what
that reality is. It is a crucial act of independent thinking to be
skeptical of someone else's description of reality.'-
Howard Zinn
Any ideas ?
Thx.
Jez, MBA.,
Howard Zinn
