G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hello Group
I have been having a bit of trouble with a Newly installed ATI AIW 9800
Pro
I normally try to playback Video from a DV camcorder and capture the
stills " At a Pre Determined Setting of 320 X 240"
When i Open up the Latest ATI Media player and place my still settings
at a 320 X 240, then adjust the Option to Save as JPEG,
It does not, It always saves at 640 X 480 and saves in Bitmap Format.
Has anyone had similar experiences with this Problem and does anyone
know how to fix the problem and have is Permanantly save in 320 X 240
Jpeg Format?
My PC is 3.2 G AMD,...1GB of Ram ...OS Running XP 2
Any help would be GREATLY APPRECIATED!
Thanks in advance
Tobey
Hello Group
Pro
Jpeg Format?
Thanks in advance
Tobey
