Help with Tvout G45 dual head
Archived from groups: alt.comp.periphs.videocards.matrox (More info?)
I've got a Matrox g450 dualhead, and I know I can get it to drive a TV
( I've got the correct vga-composite/s-video dongle) because I can go
to
Settings>advanced>dual head>TV-out>TV adjustments>change settings
And get color bars on my secondary composite TV monitor. So far so
good, I know the hardware works
My problem is I cannot get it to display any video on the TV (except
the color bars of course). I'd be satisfied with a clone of my main
display, and video output from the MyTheatre software I'm using (or
vlc)
I have the options
Dual head multi-display (disabled, but works* when box chkd)
Dual head clone (greyed out, will not let me use)
Dual head zoom (disabled)
Dual head dvdmax (enabled but not currently active)
* works means displays on the composite monitor
Can some one give me a clue
Remove 12 to reply
1 answer Last reply
More about help tvout dual head
  1. Archived from groups: alt.comp.periphs.videocards.matrox (More info?)
    cntrl f10 did the trick
    obvious in retrospect;)
    Remove 12 to reply
Matrox TV Video Graphics
