G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
All:
I'm running a Highpoint SATA RAID card under Windows XP Pro, and it works
well enough I suppose (although the support is abysmal and the driver
updates nearly undocumented). But it doesn't support windows power
management, so the disks never spin down. 3Ware's web site indicates they
don't either, and for a home server it's a real disadvantage having
(multiple) disks spinning 24/7 - lots of heat and noise. Anyone know of any
way to mirror a pair of drives under XP and get them to play nicely with
power management?
Thanks,
jhd
All:
power management?
Thanks,
jhd
