G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.storage (More info?)
I often move my hard drives around between my home PCs. I use 80-conductor
ribbon leads. All my hard drives are configured for Cable Select.
When I have two hard drives on my primary IDE port and I remove the one at
the far end then my BIOS recognises the drive in the middle but then it
stops booting and says
"Primary Master Hard Disk fail".
Is there some sort of terminator I can put on the end of the ribbon cable to
fool the BIOS that the primary master drive is there?
