Archived from groups: alt.computer,aus.computers,comp.sys.ibm.pc.hardware.storage (More info?)
I am having trouble with a hard drives on the system below. I just got a
replacement for the ATA100 45GB IBM drive which died, an ATA100 80GB
Hitachi. When I sent the IBM back, I also bought the 160GB Seagate SATA and
put a fresh install of WinXP Pro on as I lost it when the IBM died. Now I am
trying the get the Hitachi back onto the system and when ever it is
connected to ANY of the 4 on-board or 4 PCI ATA controller channels the
system will not boot, opting to either boot off CD or saying there is a boot
disk error depending on the boot sequence and options. The motherboard does
not have any option to boot from SATA, 'RAID' being the closest option which
still does not work. I know the jumpers are right (except trying 'disable
auto-spin up') and as soon as the drive is removed it boots fine off the
SATA. The drive is currently formatted for NTFS with a bit of data I grabbed
off a mates machine and was formatted using Partition Magic. Is there
something in the boot sector of the SATA drives which tells the system which
ATA drives to ignore, therefore if another is added it does not know to
ignore this drive and attempts to boot it like any normal ATA?
Cheers Guys & Gals
Brad
System is:
Asus A7N8X- Deluxe 2.0 | 2500+ AQXEA 0330RPMW | 1.70v vcore | 2200mhz 11x200
| 512mb PC3200 Geil 6-3-3-2.5 | Hercules Geforce 3 Ti200 | 230/500 | 160GB
Seagate 7200.7 SATA | 45GB IBM 45GXP ATA100 | 15GB IBM ATA100 | Enermax
Black Tower Case | 300x Enermax PSU
Cheers Guys & Gals
Brad
System is:
