G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I've had a Maxtor One Touch 160G drive for about 2 weeks now. Just one concern
though. Often when it starts up it will clang/bang quite loudly for 3 to 20
times, at a rate of about 2 times a second. It makes quite a racket. Then it
settles down never to do it again for that session. It only does it on startup,
and does it whether connected to the computer or not, although occasionally it
won't do it at all. The drive seems to work fine in all other respects. I've
googled about a bit and found nothing on this noise. Is it normal or is it a
defect or sign of impending doom? My old BUSlink 40G external drive makes no
such noises. I have about 2 more weeks to bring it back. should I?
