Archived from groups: comp.sys.ibm.pc.hardware.storage (
More info?)
Ignore the clueless troll.
He obviously stopped reading after the first line and has no idea.
"Al Dykes" <adykes@panix.com> wrote in message news:c76iei$q8j$1@panix3.panix.com
> In article 1edd5375.0405031446.678f4350@posting.google.com, bmpgifjpg <bmpgifjpg@yahoo.com> wrote:
> > My hard disk is making the reading/writing noise every two second and
> > it's bothering me. (I counted that there are 30 such noises in one
> > minutes). There does not seems to be any problem with my hard disk
> > other than the noises, I am able to read files from the hard disk and
> > write files to the hard disk at the usual speed.
> > My hard disk started making such annoying noises yesterday when I got
> > invaded by msbb spyware. After removing it with Ad-Aware, the noises
> > won't go away. I notice that if I press Ctrl-Alt-Del to bring up a
> > dialog box that show all tasks on my computer, the noises will stop,
> > and it will start again after I click cancel to return to windows.
> > Here are the tasks that is listed in the task dialog box: explorer,
> > systray, zonealaram, avg??? (anti-virus software from
www.grisoft.com). The tasks seems normal to me, I don't think the
> > noises are caused by any of the tasks. My hard disk is more than 3
> > years old but I don't think the noises are caused by the old age
> > because the hard disk works fine since I bought it 3 years ago. The
> > hard disk only started making annoying noises yesterday.
> > Please help, I want to know how to get rid of these noises which
> > bother me. Thanks in advance.
> Copy your data ASAP and then prepare to buy a new disk drive.
> It's best of you turn you machine off RIGHT NOW. The less yuo use the
> machine the better chance you have of recovering your data.
> If you buy a new disk and install the OS you can then connect the old
> disk as a secondary and copy the data off it. If you're lucky.
> Otherwise`q and look for help from a friend that has a PC with the
> same operating system on it. Take the disk out of your machine and
> make it the
> You could copy data to a USB backpack, or burn a CD, but the less
> you use this disk the better your odds are.
