G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I setup a new server in an office. It is a very loud server tucked away in
a sound resistant cabinet. To allow easy backup media swaps, I setup the
backup so that it backs up to a removable IDE drive in the secretary's
workstation. She swaps the drive out every morning.The server runs Server
2003, the workstation runs w2k. This setup ran fine for weeks.
The drive is shared as "BACKUP" and I have the NTBACKUP on the server backup
nightly to the drive. The strange thing is, lately the backup has not been
going and the log says something like "specified media not available". When
I run the backup job manually, I have no problem and the media is always
found. It is very odd, the backup used to go every night no problem and
this issue only started recently. The backup is actually run by a batch
file with the detailed NTBACKUP command line, I use Task Scheduler to
schedule the batch file to run. To manually backup, I just double click the
batch file so it should be exactly the same as if task scheduler runs it.
I have a few ideas, like maybe the workstation is powering off the network
card to save power? I can't find power settings in w2k for this card, so
maybe that isn't it. Anyway, before I really tackle this one I thought I
would see if anybody had any ideas or suggestions on improving my setup.
ANY TIPS APPRECIATED!
Thanks,
--Dan
Thanks,
--Dan
